Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 05-27-2002, 12:26 PM
whprelude's Avatar
whprelude whprelude is offline
Question what this guy told me at a new import shop
ok, first off ppl, i know nothing about lowering a car. i'm wanting to lower my ride simply for looks and handling. so i went to this new car shop that recently opened up. i told the guy that i wanted to lower my car and asked how much would it cost and he said around 250.
i do know this, that whenever you lower your car, you defintely need a camber kit. i asked him if that included the camber kit and he said no and that i wouldn't need it. just said i would need an alignment.
he also said it would be 1.25" drop in the front and 1" drop in the rear.
so my question is should i trust this shop with lowering my car with their stuff or should i buy my on?? and if so, whats a good brand(including the camber kit)?? thxs in advance!!
92 White Prelude
-h22 vtec
-Wings West Big Mouth
-Wings West RS Series Sides/Rear
-Iceman CAI
-DC Sports short shifter
-Stage 1 clutch
-Apexi megaphone dunk
-Jdm headlights w/blk housing
-18" RS Limited
-J Power cross drilled rotors
-mirror tint
-tail covers
Old 05-27-2002, 04:50 PM
onesojourner's Avatar
onesojourner onesojourner is offline
Send a message via AIM to onesojourner
you have a prelude right. if it were me ide go with an eibach pro kit thats about a 1.5 drop your car is fairly low to begin with. i would also get some diff shocks. the KYB agxs will work great with those springs. groupbuycenter.com has pretty good prices on this combo. i dont know if youll need a camber kit with this set up or not. just have the money in case you need one. you will deff need and alignment.
don't like my post
The things you own end up owning you-Tyler Durden
videos
Old 05-27-2002, 07:04 PM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
Don't pay 250 unless you're getting coilovers. Just buy the springs and do it yourself, there are tutorials all over the net. And with a one inch drop, you're gonna waste your money with a camber kit, but yeah do get the alignment.
Old 05-29-2002, 06:49 AM
HookdUpTeg99 HookdUpTeg99 is offline
I've had my ground control coil-overs on my integra for almost a year now with it dropped to about 2" and no camber kit and i have no noticeable uneven wear on my tires. Yes, the front wheels do sit in a little bit and the back ones do barely, but if u live somewhere where there are a good amount of turns and not just str8 driving for miles and miles u will be fine cuz the wear evens out :alien2:
'99 Red Integra LS
- Ground Control Coil-Overs
- KYB AGX Adjustable Shocks
- 17" Konig Toxxins w/
205/40/17 Kumho Ecsta Supras
- Mid-Wing Spoiler w/ LED
- Injen Cold Air Intake
- Pioneer Head Unit w/ Animation
- JL Audio 250/1 Amp
- 2 10" Alpine Type-R Subwoofers
- Reverse Indiglo Titanium Face Gauges
- Hyper White Headlights
- Clear Corners
Old 05-29-2002, 10:44 AM
AND, since you've got 18s, your tires are gonna sit fairly staight up and down since they're so wide.
Old 05-29-2002, 06:07 PM
rendog24's Avatar
rendog24 rendog24 is offline
even if u do need a camber kit, which u most likely wont, then just pull the ol' washer/bolt trick. its somewhere around here....
"Don't touch what you can't grab, End up with two backhands, Put anthrax on a tampax, and slap you 'til you can't stand" - Eminem
Old 05-31-2002, 11:48 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Cant do the bolt/washer trick on the front goof
But with 18's and only an inch or so drop, they are right all you will most likely need is an alignment.
AF's Official Asshole
RIP AUNIE
Old 06-02-2002, 12:18 AM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Hey
whprelude, hey are you in Fayetteville? Is the place your referring too called Suha Motorsports formerly known as Car Versions 2 on Yadkin? If it is... You should email me.. I live in Fayetteville, and me and my guys do all our own work.. That task is probably one of the easiest mods to do.. If you want I will show you how, I have a garage we could do it in... Whatever you do do not take it to the other guy!!! DO NOT I will tell you when you email... [email protected]
