Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 11-07-2005, 05:56 AM
bakyrd_mechanic bakyrd_mechanic is offline
Send a message via Yahoo to bakyrd_mechanic
Angry timing chain getting frusterated.
ok well my friend blew a head gasket in his 86 toyota pickup 4x4 22r. so we ripped it apart and found that most likey a boat mechanic worked on it siliconed the head bolts and everthing els he could together. We got it all back together and pulled it out and snaped the timing chain.. pulled it back in and torer down and bought a new timing chain set and it was a 96 link... its to small and wont go on, ok so get the other 98 link chain.... to big and skips. not sure what year the head is becuase it was replaced from prev. owner but the ports on the head are round with the round egr ports on top.. One more werid thing is thats theres no oil in the filter... but theres no ticking from dry lifters.... so i donno anyone help thats had this problem.
Old 11-08-2005, 01:21 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
In late 84 the dimensions of the head and block height of the 2R/E changed. You could have a mismatched set, but it's doubtful. Go here to help ID your head. They also have a page on IDing blocks.
Most likely you're not installing the TC corrrectly.
Here's an excellent article on TC installation.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 11-08-2005, 05:49 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: timing chain getting frusterated.
put the off colored links on the dots of the crank gear and cam sprocket
if the engine is a single row chain on it then its most likely a late 84-up
which is all the same through 95
the odds of the head being older double row chain style are slim, but not impossible
the 86 set should be it, is only one set for them
should be no issue at all
silicone all over is not good
if a bit of it ends up in the chain tensioner then that can be real bad for it,
the chain can be a bit tough to install on these, are real tight fit usually
but i hope you are not trying to install it with the tensioner and guides already on the engine
dont do that
put the chain and gear and sprocket on first
then put the tensioner and guides on
very simple, easy
if you have to turn anything slightly to get the sprocket onto the cam then turn the cam with a punch in the hole in the front top of it by the front cam cap up there, cant miss that hole in the cam
as long as colored/bright/dark chain link stays on the cam sprocket dot then it doesnt matter, wont have any problem of any kind
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 11-09-2005, 08:56 AM
ok well i havnt taken the intake manifold off yet but the exaust ports are round telling me that the heads pre 84 (local machine shop told me) weither the intke ports are round or square is the difference that i need to know. but now by going off round ports pre 84 it would be the 98 link chain. but theres ALOT! of slack in the chain untill the ten. it fully extended but on a comp. stroke for #1 it skips time. just wondering if theres a blockage in an oil passage somwhere (creating the no oil in oil filter) beacuse i noticed this ten. are ran off oil pressure.
Old 11-11-2005, 07:16 AM
SidneyCanada SidneyCanada is offline
22R Series tech data:
http://www.babcox.com/editorial/ar/ar119838.htm
http://www.babcox.com/editorial/ar/ar400108.htm
http://www.toyotaperformance.com/4_cyl_tech.htm
http://www.lcengineering.com/TechNotes/TechNote48.htm
http://www.off-road.com/toyota/tech/...toy_motor.html
http://www.off-road.com/toyota/tech/other/4_dts.html
http://www.4x4wire.com/toyota/faq/parts/
http://www.geocities.com/MotorCity/P...ct/Engine.html
http://www.toyota-mods.org/engines.txt
http://www.toyotagtturbo.com/engines2.html
http://www.engnbldr.com/ToyotaHotlicks.htm
http://www.bitwalla.com/cruisers/info/engines.html
http://www.off-road.com/tlc/faq/engine.html
http://www.jnc.farpost.com/toytech.html
http://lcengineering.com/TechNotes.htm
http://www.buschtaxi.net/de/01info/motoren.html
http://www.landcruiser.hu/motorok.html
These sites explain the timing chain replacement well:
http://yotarepair.com/22R%20timingchain.html
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
http://www.4x4wire.com/toyota/maintenance/timingchain
http://www.4x4wire.com/toyota/reviews/doatimingchain
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:[email protected]
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 246 000 KM
