Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 11-07-2005, 12:54 AM
localboi23's Avatar
localboi23 localboi23 is offline
Send a message via Yahoo to localboi23
Question lsvtec help!
Hello all and greetings from Iraq! I will be finishing up my last 59 days here and will continue my build on my 97 custom Civic back in Hawaii, but need some input on an engine swap. I have been looking at a B18C5 but got distracted by a Dart B20 block with an 84.5mm bore, 2.2L eagle stroker kit, with a B16b head? Well now I don't think I want to spend that kind of money on the motor since I put alot of money into the rest of the car, so now I been checking out an lsvtec motor. I want to know if I purchase an engine build from TPR for $3,900 (brand new) if that is a good deal? Or should I just look around for a hand me down B16b and just throw on a turbo? Either way I want to run an lsvtec that will handle boost from a Drag GEN III turbo kit. Please help me out on making a motor purchase.
Old 11-07-2005, 10:18 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: lsvtec help!
B18C1 (GSR) is my choice. Its more expensive than the B16b, but it has a little more power and a little more potential.
www.passwordjdm.com
www.hmotorsonline.com
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-07-2005, 12:12 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: lsvtec help!
hawaii huh. which island ?
anyways. just get a ls block, put on a vtec oil pump, get arp rod bolts. slap the vtec head on with the GE kit and your all good.
Team Lonely Drivers
Old 11-07-2005, 12:41 PM
Schister66's Avatar
AF -Advisor
Re: lsvtec help!
i thought it was alot harder than that....that almost sounds kinda easy....
Old 11-07-2005, 12:59 PM
Re: lsvtec help!
well the 2 main things you want to look out for is the ls oil pump which doesnt flow as much as the vtec oil pump so you might get oil starvation as the higher rpms. 2nd the ls's rod bolts will stretch at the higher rpms, now if they stretch and break will that will lead to a blown motor.
but also putting on arp rod bolts isnt that easy because of the torque required it can warp the rod, you are suppose to take your rods to a machine shop to get them rounded so you dont spin a bearing
Team Lonely Drivers
Old 11-07-2005, 01:00 PM
Re: lsvtec help!
oh yeah then you need to bolt the head up which the oil lines, dowel pins and new hg. then you gotta wire up for vtec and run a vtec ecu
Team Lonely Drivers
Old 11-07-2005, 01:22 PM
Schister66's Avatar
AF -Advisor
Re: lsvtec help!
it sounds a little harder.....
but definatley doable...
Old 11-07-2005, 09:01 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Re: lsvtec help!
amen
rods and bolts are the key to a LSVTEC lasting *other then pump*
Old 11-15-2005, 01:46 PM
S13wanabe's Avatar
S13wanabe S13wanabe is offline
I get my built LS/Vtec back on Friday. garanteed 210+ wheel horsepower NA. I'm incredibly anxious. Oh yeah 91 octane too.
Old 11-15-2005, 01:54 PM
Ace$nyper's Avatar
Banned
Re: lsvtec help!
setup and pics
at 12:01am friday !!!
Old 11-15-2005, 09:15 PM
Re: lsvtec help!
true dat
if you claim whp numbers, you should put up your setup with pics
Team Lonely Drivers
Old 11-15-2005, 10:39 PM
Schister66's Avatar
AF -Advisor
Re: lsvtec help!
Old 11-16-2005, 12:37 AM
S13wanabe's Avatar
Yeah I know. I will get it all up ASAP. I will pick the motor up Friday and start to put it in early Saturday but probably won't finish getting it in until Monday afternoon just because of my lack of time because of shitty work. But I will post picks of the motor ASAP. As far as what's done to it: fully blueprinted and balanced, micropolished crank, ITR pistons, Portflow prepped head with slight port & polish and three angle valve job, all portflow accessories in head, Skunk2 stage 2 cams, all basic bolt-ons including the intake manifold which will get me a whole 2 hp, Mugen chipped ecu, aluminum flywheel, act unsprung 6-puck clutch and pressure plate. When I get more money I will get Hondata and squeez a little more hp out of it. All the work was done by Power Pros in Westminster. You guys should hit him up if you want an NA motor built. The guys name is Doug and I can post a phone # tomorrow.
My car is a 1993 Civic 4-door, fully stripped including all power steering, ac, heater, and any little bit of anything I could take out. I even took out that black shit under the seats with a chissle, energy suspension bushings everywhere possible, Skunk2 strut bars (got them for dirt cheap), 15" Rota Slipstreams, Falken Azenis RT615, RS*R race springs, KYB AGX shocks, 2.5" exhaust with high flow cat and ES tuning muffler, gay altezza tail lights from the previous owner of car (if you have stock lights please send), soo to have a 5 or 6 point roll cage. When I have more money seats and harnesses will follow roll cage.
