Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-06-2005, 10:39 PM
windcalmer's Avatar
windcalmer windcalmer is offline
98 civic EX headlight bulb question...
Is there a trick to getting the power connector off the bulb? I have been trying to get damn thing off for hours now and it just sits there laughing. All of the directions that i have found say to pull it off. I have pulled and pulled and nothing. Is there something i am missing? Also do you need to remove the power-steering fluid res. in order to get the drivers side bulb out, my hand is way to big fit back there.
any help would be great.
(Just an aside)
When i find the idiot mechanic that put my oil drain bolt back on with an impact wrench I am going to squash him.
On a good day Hell can look alot like L.A.
Old 11-07-2005, 12:03 AM
wakeboard_dude5 wakeboard_dude5 is offline
Send a message via AIM to wakeboard_dude5
it's been a while since i last changed bulbs.... but i believe there's a small tab on the connector that you push down THEN you pull. did you get the bulb out of the housing yet or are you still trying to get it out? as for the power steering resevor, i don't know many people with small enough hands to get in there. Just pull it straight up and it'll be able to move enough to get out of the way.
1993 civic EX coup auto SOLD! but i'll miss her
1996 Civic CX w/ B18c1 swap, small bolt on's, 2000 front end
Old 11-07-2005, 12:09 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: 98 civic EX headlight bulb question...
press tabs on side then pull. as for the drain bolt, use a breaker bar or extra wrench for more torque.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-07-2005, 03:51 PM
windcalmer's Avatar
Thanks as always. as for the bulb i have not yet gotten it out. Going to go try again now. And the oil bolt, buying a impact wrench this weekend. i figure why not have it around instead of needing it and having to borrow one.
Old 11-07-2005, 04:01 PM
civic_stuntin civic_stuntin is offline
that guy said you can just pull up the resevoir and they say you can, but still it's a tight squeeze, your better off just removing it, that's what i did and it made it way easier to get to the bulbs
Old 11-08-2005, 08:30 PM
windcalmer's Avatar
I got it done. Damn thats a tight sqeeze on the drivers side. I did it without removing the powersteering res. Now all I have left to do is to adjust them and im done. Thanks for all the help guys. This forum is great. until the next time i get stumped.
