Old 11-06-2005, 10:15 PM
1BadBowTie 1BadBowTie is offline
Send a message via AIM to 1BadBowTie
engine cuts out?
hey got yet another question for yaz, when ever my truck sits for more then 30 mins after i go to drive off it feels like the engine cuts a 1/4 of its power right after i hit the throttle?? has any one else had that. it clears up once u hit the gas a lil harder, but i'm also averaging like 13-14 mpg so im wondering if they are connected? ha i'd still rather get 13 mpg with my truck than 30 with a toyota, lol
1998 K1500 Silverado 350 5-Speed
1999 Lumina LTZ
1984 Oldsmobile/Hurst
Old 11-07-2005, 12:40 AM
2000CAYukon 2000CAYukon is offline
Re: engine cuts out?
Fuel Pressure regulator or stuck injector. Pull the vacuum hose on the regulator, if you see gas, the diaphram is leaking and needs to be replaced.
//2000CAYukon
Old 11-07-2005, 08:17 AM
LongIslander26's Avatar
LongIslander26 LongIslander26 is offline
Re: Re: engine cuts out?
//2000CAYukon
Your throttle body may need to be cleaned as well. I believe there was a TSB about that.
ASE Certified Automotive Technician
ASE Certified Service Consultant
ASE Certified Parts Specialist
Employed at an Independent Shop
Vehicles:
2005 Silverado LS Crewcab 4X4
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 11-07-2005, 02:16 PM
i just replaced the fuel pressure regulator like 1000 miles ago, so i know it cant be that, i cleaned out the throttle body not long ago but i guess it could be time again
1999 Lumina LTZ
Old 11-07-2005, 04:21 PM
Pull the vacuum hose to be sure. Also, if you have a fuel pressure tester, hook it up and start the engine. Shut off the engine and watch the pressure. It should hold. If it drops off then it the regulator or leaking injector(s).
//2000CAYukon
