Old 11-06-2005, 09:10 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
4th Gen Front End Replacment
As you can probably see I have a 94 Camaro, how hard is it to replace the front bumper, overall time required and difficulty? I have looked at it and overall it doesn't seem to look to hard to replace. There doesn't look to be that much bolted on to it. One thing I am worried about is the airbag sensor and how to do that.
White 07 STI, Bone stock for now
Old 11-06-2005, 09:24 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
Re: 4th Gen Front End Replacment
ive seen the front nose clip be removed while an engine swap was going on are u talking about the front nose? or just the bottom of the front
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 11-06-2005, 10:46 PM
ViperJ's Avatar
I think its the whole front clip, I didn't know there were 2 pieces. I need the whole thing off, from the sidemarker lights in
Old 11-06-2005, 11:26 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
With an extra pair of hands I can remove and reinstall the whole front (splashguard/air dam, nose, bumper honeycomb/support) in just over an hour
Get the car up on ramps or jackstands... remove the splashguard assembly (leave the air dam attached), it's maybe 8-10 10mm bolts running along the edge holding the splash guard to the nose and 5 8mm bolts bolding the air dam to the lower radiator support.
Once that is off, remove the bulbs from the turn signals.
Next on each side is 2 10mm nuts holding the upper rear part of the nose to the fender... may be 1 extra screw in each side. They are screwed onto studs that are in the fender.
Once those are off (and the backing paltes they hold on), pop the hood. Use some needle nose pliers on the 7 or so push pins that hold the top of the nose to the headlight bar. (You want to lift up on the inner part, once that is popped up 1/4 to 1/2 inch you should be able to gently pull out the whole fastener.)
Then there is a bracket on each side, it will be pop riveted to the outside of the headlight well and attached to either the frontmost fender bolt or screwed onto the radiator support. Take those bolts out, the manuever the nose as necessary to remove it.
The bumper support is held onto the frame rail extensions by three 1/2inch nuts on each side... may take some creativity to get to them. Once those are off the bumper and bumper support can slide right off, but be remember to take the foglight bulbs out first so you dont yank out the wires. Shouldn't have to remove the headlight bar.
Good luck!!!
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 11-06-2005, 11:32 PM
oh and dont worry, there's no airbag sensor up there. The airbag control module (located below the center console) has a built in sensor, a "decellarometer" if you will that it uses, combined with computer input such as speed, how hard you hit the brake, etc. to decide when to deploy the airbags. That's how my 97 is at least.
It is this little silver box...
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
