Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 08-01-2001, 03:26 PM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
Question CAI with POP charger or not?
OK, well I ordered a HotShot cold air intake today.
I've read that using a JWT (or Stillen) Pop charger with the CAI is a good idea because of the funneling effect the pop charger creates.
My only concern with doing this is the following...
the only filters available for the pop chargers are the ones with that big chrome piece in the front. on a CAI system this part would be facing the ground and blocking the most direct airflow. with an HKS or Greddy type filter, the air would enter from the sides as well as from the bottom (straight into the intake piping)
Should I go with the POP or not?
Old 08-01-2001, 04:04 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
I might be wrong but I think the POP charger has more to do with the aluminum horn that comes with it than the filter that attaches to it.
Old 08-01-2001, 06:02 PM
b-b00gie's Avatar
Banned
yes, thats what I mean...
that is the benefit of it, and the benefit of using it in conjunction with the CAI...
but a draw back is that the only filters that fit on it have that metal piece at the front, which on a CAI would be facing down and blocking the air coming straight off the ground..
Old 08-01-2001, 09:38 PM
slickkedar's Avatar
slickkedar slickkedar is offline
is there any modification necessary fora cai??
Old 08-01-2001, 09:54 PM
b-b00gie's Avatar
Banned
Yes...
Next to your battery tray there is a hole which let air up into your stock airbox. The hole must be cut out and enlarged in order to fit the intake piping through it so that your filter can sit between your front bumper and your wheel well.
Old 08-01-2001, 11:06 PM
P10DET's Avatar
P10DET P10DET is offline
Re: CAI with POP charger or not?
Boogie, don't sweat it. The need for the venturi with the POP is due to the proximity to the MAF (directly attached to it). With the CAI, the effect of the venturi is rather limited due to the length of the pipe before the MAF. The airflow becomes significantly less turbulent farther down the pipe. The real turbulence occurs where the filter attaches to the pipe. It smooths out downstream.
As for the chrome piece blocking air flow, don't worry about that. You'd be surprised at how air actually flows.
Just use the K&N filter that comes with the HS CAI. You'll be OK. I don't think anyone has ever received any gains by using a POP with a CAI.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 08-02-2001, 03:44 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
CAI
Hey Guys...
with the CAI and POP, will that fit between the chassis and the
fender liner? If so, water really wouldnt be an issue, right?
-Brian Jones
I got a snake man
Old 08-02-2001, 06:26 AM
b-b00gie's Avatar
Banned
George,
http://www.se-r.net/engine/cool_air_intake.html thats where I read about the POP w/ the CAI.
Still not sure which way to go...
Also wanna put an AEM bypass valve on it. Anyone know the diameter of HotShots intakes? Also, should I place the BPV before or after the engine bay on the intake? Not sure how close it can be to the filter and still be effective and/or if that is a factor in its operation...
A380Driver,
I dont think light water "hitting" the filter will be much of a problem. For example rain drops coming through the vents in my front bumper. Water on the ground shouldnt be an issue either. If it was then you could never drive your car in the rain if you had a CAI.
The real issue comes up when driving through a puddle which is about as deep as the lower edge of your bumper. At that point the water has enough wieght to it (or around it) to physically push itself into your filter and then get vacuumed up.
Old 08-02-2001, 06:37 AM
P10DET's Avatar
Either way you will be fine.
I'm pretty sure the CAI from HS is 3".
As for where to place the valve, anywhere before the MAF is fine - the higher in the engine bay the better.
Yep. Think of your car as a 140+ hp shop vac!
George Roffe
Houston, Texas USA
00 328i
PR CAI with JWT POP FORSALE WRAITH Classifieds 2 01-13-2002 06:14 AM
CAI vs normal pop charger jalterio Engine 5 12-10-2001 10:36 PM
pop charger and CAI Atdogg77 Engine 9 11-26-2001 07:15 PM
Does the POP Charger make you car louder? Plat-num Engine 6 06-29-2001 10:13 AM
K&N Filter without Pop Charger Dprotech Engine 11 05-25-2001 02:56 PM
