Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-06-2005, 04:02 PM
nbarnette nbarnette is offline
passenger front wheel knocking???
I have a 98 eclipse, has new tire and I replaced the front wheel bearings last month. I have a knocking sound coming from the passenger front wheel. It is not a pop or grind. I have been told by the mechanic that replaced the bearings that they see nothing wrong. I am really concerned with the noise. The sound is constant and louder when I slow down.
Old 11-06-2005, 04:09 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Did they make sure and lube them up good when they replaced them? Have you checked?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 11-06-2005, 04:15 PM
They checked both of them when I took it back. They said that they couldn't find anything wrong. I drive the car about 180 miles each day. The road has alot of curves and hills. I am really concerned for safety. I am afraid that my wheel is going to fly off. The car has about 141,000 miles on it and I have never had to do any major work on it.
Old 11-06-2005, 04:29 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: passenger front wheel knocking???
Make sure lug nuts are tight, also check to make sure that the plastic insert in the wheel well isn't bending to make contact with the wheel. If it's happening when you turn, it's probably a CV joint.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 11-16-2005, 07:46 PM
It was a bad wheel bearing.
