Go Back   Automotive Forums Car Chat > Ford > Contour
Old 11-06-2005, 02:57 PM
mobil_12 mobil_12 is offline
timing belt- what did i do wrong?
I just installed a timing belt, tensioner and idler pulleys on a 1998 countour gl with the 2.0 ztec vct engine. I followed the instructions from alldata and the ones that came with belt. I also used the tool to hold the cams in place and the pin to hold the crankshaft in place also.
Now, the engine idles just fine- real smooth. But under load it shakes and pops. Sounds like a timing issue to me, so I tore it back down to make sure all of my marks lined up and the cam tool fit back in. The exhaust cam was just a little bit off. So i redid the belt install and tension and the cam lined up after 2 engine roations.
I started it up and same situation. Idles fine but misses and pops under a load. I checked the scant tool data and found the vct cam timing showing -15 deg at idle and increases to positive numbers as engine speed increases. I also found that the overall engine timing is around 30 deg. This sounds like too much but I cannot find specs for total timing or vct timing.
Im convinced that this is a timing problem, but I cant figure out where I went wrong on the installation. Please help me with some ideas. Thanks.
"The Constitution shall never be construed...to prevent the people of the United States who are peaceable citizens from keeping their own arms."
-Samuel Adams, 1786
