Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-06-2005, 02:44 PM
speedncivic speedncivic is offline
need some help
I need some help with my car. When I give it some gas, it is sputtering. It does it in 1,2,3,4,and 5. I just changed the up stream o2 sensor and a the fuel filter and it is still doing it. Any suggestions?
Old 11-07-2005, 07:26 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Does the car have any modifications, or have you serviced or had anything serviced lately other than what you said, and what kind of car? Does it do it in just a certain rpm range, or in any range?
Old 12-14-2005, 05:01 AM
JDMcivicEG JDMcivicEG is offline
if it sounds like a lawnmower check the plugs, wires and distributor it could not be getting spark.
Old 12-14-2005, 05:54 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: need some help
sounds like only running on 3 cylinders, check plug wires
Team Lonely Drivers
Old 12-14-2005, 06:06 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: need some help
pull the plugs and look at them....post pics of them so we can see what's up if you don't know what to look for.....the i would say check the wires if not get new ones.....
If neither of those is the problem, you could check the distributor.....If it isn't spark related, then we start lookin elsewhere!!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
