Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-06-2005, 03:01 PM
mystic37601's Avatar
mystic37601 mystic37601 is offline
What wld make a battery crank but not start?
I tried searching the forum, but guess I didn't word it right, cldn't find a response. What has happened is that I've been having battery problems. My battery was drained dead. I bought a battery charger & had it hooked up to my battery, then left the house. I'd broken up with my boyfriend earlier that day. While I was gone, he called & left a message saying he came by the house & saw where I had my battery charger hooked up & he slung it. Then he sent a text saying my car would never start again. Well, when I got home, the battery charger was on the ground, but said "charged". It was still hooked to the battery. I took it off & put the cables back on. When I tried to start it, it would crank, but never would start. Just kept turning over. What could he have done to my car, maybe took loose, to make my car not start now? I've heard of something, I've checked all the plug wires & they're all plugged up. I can't see anything unplugged, but I'm far from a mechanic. I would appreciate any input on what he could've done to my car to cause it to turn over, but not start. Hopefully it's something small that I can find & put back on or something. Thanks for any helpful responses.
1995 Mitsubishi Eclipse RS
2.0 Automatic (soon to be
Manual when I can save up
the $$)...It's a work in progress
Old 11-06-2005, 05:24 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: What wld make a battery crank but not start?
I assume this jerk had access under your hood (no pun intended) He could have switched the order of the spark plug wires on the distributer. It should be when you are looking at your engine from the top in front of your car: Top left of dis to far left spark plug, Bottom left (front) of dis to middle left spark plug, Top right of dis to far right spark plug, Bottom right of dis to middle right spark plug.
He could have also removed a fuse from under the hood. Grab your manual in the glove box and compare to the diagram.
Check in your muffler. Maybe he plugged it with something.
Sand / sugar in the gas tank? Oh I hope not. Did it start up initially and then die?
Check everywhere for something disconected. By the way how much does he know about machanics?
Take that text message to the cops, charge the f*ck#r.
O.K. Boys, round up the troops! Let's see if we can get this poor girl some help. She's obviously having a rough time.
P.S. I know a guy who loves breaking people's legs............Nancy Caregan style.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 11-06-2005, 11:55 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Yeah i'd say take it too the cops, make the fucker pay. If you can take the car to a mechanic have them overcharge you, then take the bitch to civil court! Don't forget to miss some work too!!
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 11-07-2005, 11:33 AM
MexRocket's Avatar
MexRocket MexRocket is offline
..... maybe you just need a new altenator, or spark plugs..... you could also start his house on fire, its getting cold out..
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 11-07-2005, 09:18 PM
Just wanted to let ya'll know that I found out what it was...I had to talk to him again, to get him to come fix it, because the way he was talking it would never run again. It turns out that he just unplugged the coil pack. I didn't even notice it. But thank you all for your advice (about the car & him) I appreciate it...
Old 11-08-2005, 08:52 PM
Good to hear that things are working out for you. I'm glad he didn't do any damage.
Old 11-11-2005, 02:30 PM
Talont28 Talont28 is offline
Send a message via AIM to Talont28 Send a message via MSN to Talont28 Send a message via Yahoo to Talont28
id check to make sure you coil pack is still pluged in...is your car standard or auto?...if standard try having someone help u push it and start it that way...
Its a Dsm thing...
<img src="http://www.dsmtuners.com/gallery/data/500/44010Pcdv0154-thumb.jpg">
