Old 11-06-2005, 10:54 AM
albert3029 albert3029 is offline
Angry Headlight Problem With 94 Gt
When using my headlights on my 94 GT they dim out, sort of go on and off, my corners stay on though. Also happens when using my high beams, but if I hold the handle to the high beams they stay on until i let them go. Any suggestions??
Can this be the relay? If it is where is it located? Thx!
Old 11-06-2005, 12:10 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Headlight Problem With 94 Gt
Do they just dim when you are at idle or is engine speed unrelated?
1969 Cougar
357w & TKO - 475hp
Old 11-06-2005, 12:25 PM
Re: Re: Headlight Problem With 94 Gt
They dim out while driving and idling.
Old 11-06-2005, 01:08 PM
351wStang's Avatar
How does your voltage guage read when they are doing this?
1969 Cougar
357w & TKO - 475hp
Old 11-06-2005, 01:31 PM
Volt gauge is normal, alternator tested normal also.
Old 11-06-2005, 02:16 PM
351wStang's Avatar
Have you checked to make sure you have a good connection? What kind of condition is your ground wire in?
1969 Cougar
357w & TKO - 475hp
Old 11-06-2005, 06:40 PM
What connection do you mean?
My ground wire looks alright had to disconnect the other day because it was dirty from the battery terminal, car wouldn't start until i cleaned it and shifted the negative terminal a bit.
Not sure if something is loose or what.
Old 11-06-2005, 07:52 PM
351wStang's Avatar
Check to make sure your headlights are plugged in good and nothing is loose. If they just alternate going dim/bright while driving it sounds like something may be loose and getting a weak signal. Kindof like the headlights are being plugged in and then unplugged and plugged back in. Do you understand what I'm trying to say? Hope I havent confused you.
1969 Cougar
357w & TKO - 475hp
Old 11-07-2005, 05:51 PM
I got what your trying to say I tried that lights seem to be in tightly, I do think something is loose but don't know what.
Old 11-07-2005, 08:53 PM
351wStang's Avatar
I re-read your first post. The part about holding the h-beam handle makes me think it may be a short in the switch. I've never dealt with a '94 GT. Are there any contacs in the switch that you can access to clean? I think your getting an intermittent signal from something. Just keep digging is all I know. Run the wires from the switch to the headlights. Maybe somewhere in your search you will find the grimlin. Good luck.
1969 Cougar
357w & TKO - 475hp
