Old 11-06-2005, 10:10 AM
williejdub williejdub is offline
can i put bigger tires on my 1500 hd
i want to know if anyone has mounted 285/75 /16 on the stock rims of a 2003 1500 hd., without a lift.
Old 11-06-2005, 12:39 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: can i put bigger tires on my 1500 hd
should work fine! I believe I put some 285's on a 1500 before. But I do so many tires that i dont really remember. And welcome to AF!!
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 11-07-2005, 07:32 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
285's should fit with no lift without a problem. You may can even fit 305's, but then you have to crank the torsion bars like hell.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 11-08-2005, 03:56 PM
01silverado03z400's Avatar
01silverado03z400 01silverado03z400 is offline
Send a message via MSN to 01silverado03z400
I went to Costco yesterday and they said that 285 was too wide for the stock rim. But I dont believe him so I'm gunna look around at other places.
NEW - 2004 Chevrolet Silverado 5.3L RCSB Z71 Hooker AeroChamber - Black Bear Tune - Welds - 33" Mickey Thompsons
01 Silverado 4.8L ECSB 4x4 True Flow - Magnaflow - Black Bear Tune - 35" BFG A/T - 4.56 Auburn SOLD
83 Sierra RCSB 2wd 350 Under construction
Old 11-09-2005, 07:30 AM
jeverett's Avatar
That's a lie. I have 285's on mine.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 11-09-2005, 11:11 AM
korndogg's Avatar
yeah they dont know what the hell their talking about.
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 11-11-2005, 05:05 PM
3wbdriver 3wbdriver is offline
The 285 is almost 11" wide at the sidewall. In my early years of 4 wheeling, I was made to understand that you shouldn't run a wheel that was more than 2" narrower than the tire width. The dealer was probably referring to this argument when they said the tire was too big for stock rims. I'm sure the tire would mount, but you might be giving up some side flex because of the narrow stock rim. Most stock rims are only 5-6" wide. I put 16 x 8's on my truck, with the intention of mounting a 245-265 range tire when my original skins wear out. I'm not saying they won't fit stock rims, just that they might not perform as well with a better matched width wheel. I know my old Blazer has 35-12.50's on 10" wide rims, and everything looks and feels right. I originally had 36-14.50 bias plies on the same rims, and the center tread always wore out first, regardless of what I ran for pressure. I believe this happened because the tires were sucked in at the center bead -if you will- and it hurt the contact profile of the tire. Would this happen to a steel belted tire? I doubt it, but it's worth thinking about.
GAS IT TIL YOU SEE GOD, THEN TURN LEFT!!!!!!
Old 11-13-2005, 07:02 PM
I had the 285,s put on this weekend. had to trim some of the plastic lower bumper guard, and a little bit of the mud flap. no rubbing now, and looks good
