Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 11-06-2005, 09:55 AM
horn1 horn1 is offline
Question 2001 dakota headlights
I have a 2001 Dakota with headlights not working. We have checked
the fuses, relays. I have no power going into my headlight switch
because of a bad headlight fuse. The bad fuse is the dashlight
fuse. Has anyone else had this problem? Is there something I'm
missing? Any help will be greatly appreciated.
Old 11-19-2005, 09:48 PM
knox 000's Avatar
knox 000 knox 000 is offline
i have the same problem. the running lights work but as soon as you turn on the h.lights they flicker or dont work at all if you have the same thing i posted for help here no one knows anything havent fixed it yet check the recalls for your truck there was one for mine and they said they fixed it but now a year later its malfunctioning and they claim its a seperate problem i call bullshit but thats how dealerships work if u figure it out let me know. i will keep u posted.
Old 11-22-2005, 07:19 PM
1thunder 1thunder is offline
Re: 2001 dakota headlights
remove the left kick panel and disconnect the central timer modual 3 connectors let sit for approx 5 minutes and reconnect and try lamps again this is from 2001 to2004 dakotas only
Old 11-22-2005, 11:02 PM
knox 000's Avatar
thanks for the help hope it works. let you know
Old 07-04-2006, 09:28 AM
xpress60 xpress60 is offline
Should the battery be disconnected before the CTM ? I hate unplugging things hot with airbags.
