Old 11-06-2005, 01:51 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Angry someone? anyone? im getting torqued over here!!!
I have a 92 talon n/t..... on the rack and pinion it looks like its leaking, i wipped it down and looked, its leaking from the fitting goin into th e rack on the right side... there there is actually 2 fittings, the one on the left is leaking...... and the line proceeds down the rack to the right to another fitting goin into the left side ofhte rack... i need to replace that line.... what do you call that line? and its not rubber... so what is that line called? anyone? its the line that runs under neathe the car and in both ends of the rack......
Old 11-06-2005, 03:40 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: someone? anyone? im getting torqued over here!!!
You're best bet is to go to the dealer and look at the diagrams at the parts counter. You can get the name, the part number, and then order it if you wish to do so.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
