Old 11-05-2005, 09:17 PM
vtzdriver vtzdriver is offline
00 LeSabre ABS/front hub question
The right front hub on our 00 LeSabre recently went bad and we had it replaced locally (non-dealer). The ABS/'traction off' lights were on as a result but continue to show after the replacement. The mechanic insists that we need to replace the left front also to get the ABS working again. Anyone have a similar problem and is his thinking correct or is there likely another repair needed with the one hub replaced??
Any help is appreciated.
Old 11-06-2005, 07:50 AM
polarzak polarzak is offline
Re: 00 LeSabre ABS/front hub question
I just had my left front hub replaced at a non-dealer. No problem with the ABS/traction light remaining on. Personally I cannot see any reason you would need to replace a perfectly good hub to get the ABS lights to go off. Check out another mechanic.
Old 11-06-2005, 08:34 AM
stuzman stuzman is offline
I replaced both hubs myself a few months back on my 2000 LeSabre. The right front was making the noise and I decided to replace the other side at the same time since it was probably on its way. I didn't have any problem with the ABS/traction light being on even with the hub bad.
If you have a capable scanner, you could look at the wheel speed of each sensor. Also, if you have a DVM you could check the AC voltage from the sensor and its frequency if your meter has that feature. A scope would also allow you to see the signal from each wheel sensor.
Old 11-20-2005, 07:44 AM
93buicklesabrelmtd's Avatar
93buicklesabrelmtd 93buicklesabrelmtd is offline
They didnt plug back in your wire harness for the hub. Circuit is open.
