Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 11-05-2005, 07:55 PM
TINA BERGHOLM TINA BERGHOLM is offline
Heat
I have a 95 dodge intrepid. It takes about 25 minutes for the heat to become warm after starting the car. Sometimes after I have been driving for a long time the air becomes cool, and no heat is coming out at all, other times is is warm, but never really hot. I appriciate all ideas. thanks
Old 11-05-2005, 10:31 PM
muff34 muff34 is offline
Re: Heat
Thermostat could be stuck open. How`s the coolant level ?
Life Is A Highway ,Enjoy The Ride
Old 11-06-2005, 12:22 PM
Re: Heat
coolant is good. Do I have to drain the coolant system to change the thermo? It doesn't tell me in the book I have. Thanks for your help
Old 11-06-2005, 09:46 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Heat
you don't necessarily have to drain the coolant to replace the thermostat, you will lose some coolant when you remove it, but not a whole lot. When you replace the t-stat, make sure you alse bleed out your cooling system or else you will still have no heat in your car b/c of air bubbles will form in the system.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
