gtp engine modifications help
i just bought a 98 gtp and i want to make it faster. what mods would give me the most hp? and witch would be the most economical?
Re: gtp engine modifications help
Welcome to the forum.
It depends on your goals of how much horsepower you want to gain, target ET, etc. Are you referring to bolt on aftermarket parts or are you going to have a shop do the work. ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
U-bend delete, smaller s/c pulley and cold air intake would give you a good start for under $500.
Re: Re: gtp engine modifications help
![]() ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
With the smaller pulley you want to get colder plugs
replace the chip with the jet chip- best bang for your buck
