Remote starter/keyless entry on 97 grand caravan
Hi there -
I am installing a keyless entry / remote starter system on my wife's 97 dodge grand caravan. I have 2 questions: 1) I have found several posts that indicate the resistors to be used for the door locks/unlocks: Door Lock White/Dark Green (-) BCM at Fuse Panel 1500 Ohm Resistor Door Unlock White/Dark Green (-) White Connector B58 Connector 250 Ohm Resistor So my first question is... how many watts should these resistors be rated? I walked into a Radio Shack to buy the resistors and that was the first question I was asked ![]() 2) What is the color and location of the horn output wire. I need to connect to this for the panic button. Thanks, Bill |
I have no clue about the resistors,
the horn wires in my 98 gtrand caravan are wrapped separate from the rest of thw wires in the steering column, this should make it eaiser to find. Look for a two wires: light blue and black. you want to splice into the light blue wire. |
I gave you the wrong color. I checked it on the print it is black/red, it should be in one of the bigger bundles in the steering column.
The light blue and black wires are for the key sensing |
