Rims
I dont no why but i cant seem to find out what size rims would fit on my car. My owners manual only tells me what size wheels i have but thats it.... I'm tryn to buy new rims but i dont no what one would fit on my car... I have a 93' 3000gt n/t.... If ne one can help me out thanks alot!
Re: Rims
You could put 15's on it if you really wanted LOLOLOLOL. You could go as big as 20's too if you really wanted. What are you wanting to know? Dont go any narrower than 8" wide since thats stock size and anything less is a downgrade. Bolt pattern is 5 x 114.3. I am not 100% sure but I think you need 40mm offset. You may want to double check on that though.
Re: Rims
ya, i was searching around for rim widths the other day. while converting a given rim width, say 8" to centimeter width (200cm), i was a bit confused b/c my car has 225/55/16's and how could a rim width vary by 25cm and the tire still fit?
turns out, rim width isn't that critical. the same width of tire will fit on different rim widths. i THINK the tire width (e.g. the '225' number in my example) is only the tread width. the widest part of the tire would be measure where the sidewalls bulge outwards a little bit. so basically, there are things and details to know about rims when buying.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
Re: Re: Rims
well you dont really want a rim wider than the tire itself. I have 245/50's on some 16's. They are the same diameter as the 225/55's but 20mm wider. They are on 8" wider wheels too.
But yes the first number is the tread width in mm. Take that number divided by 25,4 to convert it to inches. The second number is aspect ratio for sidewall height. so 225/25.4=~8.89inches(tread width) 8.89*.55=~4.89(sidewall hieght) 4.89*2=9.78+16=25.78 (tire diameter)
Re: Rims
I'm also confuse, i dont know nothing about rims and tires fitment, but i found some good rims and will they fit my car? 5x100 or 5x114.3 http://www.craigslist.org/sby/pts/109157344.html
Re: Rims
ok, could you guys explain the whole offset thing... I b/l I know what it is... but I don't wanna say anything until I know for sure...
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
Re: Rims
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
