Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 11-05-2005, 04:25 PM
L8R_H8R L8R_H8R is offline
Question Hydrolock?
When your engine gets hydrolocked, how does the engine run? does it completly destroy it, or is there hope saving it? can you still drive on a hydrolocked engine? thanx in advance for the help
Old 11-05-2005, 05:14 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Hydrolock?
if you get to it quickly you can pull the spark plugs out and get the water out before it really starts to get into everything. Get the plugs out and dry out the cylinders quickly. Then run the car.....because i've heard that the rings can literally fuse to the cylinder walls. I would recommend also to get an oil change ASAP....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-05-2005, 05:40 PM
Re: Hydrolock?
How exactly can water do all that much damage?
Old 11-05-2005, 07:07 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Hydrolock?
water is denser (or something) and doesn't compress like air. Basically you're filling up the cylinders with water (well, not filling it up completely), and when the pistons move up; it doesn't move the water out fast enough like the air would. So because of the water, there isn't enough room for the piston to come up all the way. But the piston isn't just going to stop, it's going to come up; and quickly. This can cause your connecting rods to bend; and your engine is screwed. Also if you just leave the water in there, it can cause rust and do just like Schister66 says.
Old 11-05-2005, 07:11 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Hydrolock?
water does not compress like air in the cylinders for obvious reasons...................so whats the pont? you bend or break a rod or blow a hole in your block. fluids in the combustion chamber will wash out your rings..................point is...................you wont have good compression, which leads to poor engine performance, or not even starting. if you want to know if the engine is salvagable, give it a leakdown and see if the motor still cranks by hand. wouldnt hurt to rip the head off and give it a look too.
what does a bent rod look like in a hydro locked car????????/
like this.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-05-2005, 08:22 PM
Schister66's Avatar
AF -Advisor
Re: Hydrolock?
i hope that wasn't your car.....
Old 11-05-2005, 10:14 PM
Re: Hydrolock?
Hey i really appreciate the in depth answer you guys are awesome = )
Old 11-07-2005, 10:33 AM
Schister66's Avatar
AF -Advisor
Re: Hydrolock?
any time....
