Old 11-05-2005, 04:17 PM
ttran203 ttran203 is offline
Cant Load or Eject discs, please help!!!
Hi, I have a Pioneer AVH-P6500dvd headunit, and just recently it doesnt eject or load disc anymore. I tried resetting it and hitting the eject button many times, it just doesnt work. So if theres anyone out there that can help please do. thanks.
Old 11-07-2005, 04:44 AM
DeathBringer DeathBringer is offline
Re: Cant Load or Eject discs, please help!!!
is there a disk stuck in it or what?...if so then u will need to open it and pull the bugger out. be careful not to force any internal parts due to the fact that there is a lot of plastic in it that will break. I found that i had a kenwood headunit and a disk got stuck in it...i opened it up and carefully removed the disk....usually most units have 2 screws holding the case together...unscrew, lift off the top (or u may need to remove the entire case) its up to you..i hope this will help
Old 11-22-2005, 08:38 PM
Re: Re: Cant Load or Eject discs, please help!!!
I can get the disc out by taking the whole unit apart, but when thats not the problem. the problem is when i try to put a disc in or to play a disc it will not work. when i insert the disc in, the motor doesnt seem to be kicking in. Therefore the disc will not go inside the unit. DO u get what i am saying? thanks for the help.
Old 12-03-2005, 08:28 PM
Re: Re: Re: Cant Load or Eject discs, please help!!!
So can anyone help me here?????
Old 07-27-2010, 02:47 AM
rahuldevshetty rahuldevshetty is offline
i have a similar problem...pls help .."hey guys ...my skoda laura music system has a peculiar problem....it works fine in all aspects except that when i want to change a cd , after ejecting a particular cd, another new cd cannot be inserted...the music sytem seems to take it in and spit it out after a few seconds...the cds already inside are playing fine and so is the radio...pls advise"
Old 07-27-2010, 07:08 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
dude, this thread is 5 years old.
