Old 11-05-2005, 03:51 PM
bovic bovic is offline
16" to 15" rims, no probs?
I have a 2001 Alero GLS Gold package, 4 disk brakes with 4 16" original mags, can I switch to 15 inches rims for the winter, it won't rub on anything, like the calipers?
Thanks..
Old 11-06-2005, 12:30 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 16
Thanks..
No problems, the swap will be OK. I'm assuming you want to go to 15" wheels for snowchains.
Timeslip 08/12/06
AF Community Guidelines
Old 11-06-2005, 09:47 AM
Re: Re: 16
No, its that winter tires tends to be harder because of our cold winter weather here, lower profile tires will be a tough ride and the 15" are less expensive also.. I just want to make sure that a 15" wheel will fit the discs and calipers, i've heard of certain cars that a 15" wheel won't fit because there's not enough clearance around the calipers.
These wheels that i'm about to get came from a 2002 Alero, I guess they're all the same and should fit my 2001..
Old 11-06-2005, 10:08 AM
BNaylor's Avatar
Re: Re: Re: 16
Oh, I see what you mean. It'll fit. Clearance around the caliper is the same either way. Up until the last year of production in 2004, the 15" tire size was P215/60R-15. If you stay with this size the diameters will match closely (24.86" versus 25.16"). When the speedo reads 65, actual speed will be around 65.78 mph with P215/60R-15. The 15" wheel width is 6" versus 6.5" for the 16". Bolt patterns are the same at 5 X 115mm.
Timeslip 08/12/06
Old 11-07-2005, 04:28 PM
Re: 16" to 15" rims, no probs?
Thank you sir.. I'll be getting a nice set of 15" wheels from that 2002 coupe, with some 215-60-15 BF Goodrich winter slalom tires as good as new. Along with wheel caps.. $400 for the whole package!..
Wife should be happy and safe with these!
