Old 11-05-2005, 02:47 PM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
Fuel Cut Defencer? need info
I was studying info on why im not getting fuel to my 92 gs...and i came across "fuel cut defencer"...but i tryed clicking the link on VFAQ.com but it keeps going to a dead page can someone give me a Link or a site where i can learn more about this?
thanks
Old 11-05-2005, 06:16 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Fuel Cut Defencer? need info
I might be stating the obvious but I don't know... fuel cut is only seen when boosting too high.... your NA... did I miss something?
Fuel pump rewiring is done to prevent fuel cut.... that's my knowledge...
here's the link that I got too for rewire... http://www.raktron.com/fuel/rewire1.html
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 11-05-2005, 06:45 PM
veilsidercng's Avatar
veilsidercng veilsidercng is offline
Send a message via AIM to veilsidercng
I'm no expert, or anything but are you acually getting fuel cut, or just no gas at all. If your car won't run at all, then you don't have to worry about that. If the fuel is "cutting out" then who knows.
'71 Mustang-fixing up then selling, hopefully for a DSM
My 1994 3000GT SL
Moms 1995 civic-Blew up
Moms 2000 Protege-upgrading from the civics 1.6L to 1.8L whooo!
Dads 2000 Blazer-hey it does burnouts AND tows the boat
Old 11-05-2005, 08:23 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Fuel cut is when the ecu see's more then 2.55g / rev. Your not hitting fuel cut. Rewireing does nothing to prevent or permote this issue.
Rewiring the fuel pump with a 40amp fuse and 12 gauge wire alows more current to reach the FP, making about 1.5-2volts more output, netting about 20-35GPH more flow out of the fuel pump.
Whats going on with your 92 GS?
DSM geek
Old 11-06-2005, 03:46 AM
kjewer1 kjewer1 is offline
AF - Advisor
If I were to guess I would say the car is not getting fuel at all, and this term just came up in a search he did and may not be at all what he really needs to know about. That being said, a fuel cut defencer is a device that tricks the ECU into not going into fuel cut at high boost. I would avoid them like the plague on DSMs, and they are of no use at all with a NT car. It will probably turn out to be a bad fuel pump, wiring, or fuel pump relay. Good luck.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
