Old 11-05-2005, 02:34 PM
bobd05 bobd05 is offline
94 Lumina APV Starting problems
Occasionally when I drive the van for a few miles it wont restart.It turns over but sounds like there is either no gas or spark.It never happens when Im somewhere I can check either of these things.If i wait a while it will start normally.It isnt running hot.Any ideas.
Old 11-05-2005, 02:47 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 94 Lumina APV Starting problems
probably a crank sensor or ignition module going bad. It could also be a leaking fuel pressure regulator. You'll need to check for spark when the van wont start to determine which is your problem.
Old 11-05-2005, 03:13 PM
Re: Re: 94 Lumina APV Starting problems
Thanks will try that.It seems this time when I start it and step on the gas while in park the engine seems to lose power about 3/4 of the way down.
Old 11-05-2005, 08:17 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
That may be the rev limiter kicking in...it'll cut it back at redline.
Don't rev a motor that hard, unless you wanna see pieces of it fly through the hood.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-06-2005, 10:15 AM
Thing is it wouldnt even rev that high before it kicked in.It cuts out around 2500 RPM.I would hope a V-6 could rev to 2500 without coming apart.Could also be Im spoiled by always driving a V-8.I did drive it and it seems that it only does it in park and neutral.thanks for the heads up.
Old 11-20-2005, 12:49 AM
the6 the6 is offline
check the oil sending unit. if it has 3 wires short out the 2 across from each other at the plug it takes 2 min. and a paper clip. sounds stupid but fuel pump won't come on if oil pressure is low.
Old 11-20-2005, 05:28 PM
Thank you.I will definitely try this out.
