Old 05-26-2002, 11:50 PM
GS-TEklipse GS-TEklipse is offline
Send a message via AIM to GS-TEklipse
Can Some1 PLZ Help? Want To Clear My Headlights
Hi all! Just bought a 98 GS-T about a month ago and I was wondering if anybody knows how to clear the headlights. The turning signals on the headlights. Is there like some place I can go to get step by step instructions or has anybody done it before. Im planning on getting projector headlights, but not anytime soon...so I just wanted to clear them for right now. Any help would be greatly appreciated, THANKS
Old 05-27-2002, 01:12 AM
ECTurboGSX ECTurboGSX is offline
Send a message via AIM to ECTurboGSX
I would warn against it. If you split the seal, your lamps will start to fog up from humidity. I would also warn you that projectors have a decreased light output. They tend to not illuminate the road as well. Do not screw up your stock ones. The 97-99 headlights are in high demand among the 95-96 guys. You could sell them if they are in good shape.
Eric
1990 Mitsu Eclipse GSX
13.4 @ 102.9
Big 16G @ 19 psi
Old 05-28-2002, 10:52 AM
Thanks man i apprciate the looking out, but im still curious and i want to experiment, does anyone know where i can go to get some instructions on how to do it? id appreciate any type of feedback
Old 05-28-2002, 04:37 PM
Alright, since you still want to do it, I will tell you how. You are going to need a razor knife, some anti-adhesive (3M is around 8 bucks for a can) and some auto adhesive and some various size screw drivers. Then you are going to pull back the rubber lining and cut it so that you keep as much of it in one piece as possible. The you will dip it in hot water to loosen the glue and then spray the anti-adhesive on it. Next you will use the screw drivers to pry the housing opening near the back of it where the turn signal is. Try to pull the orange plastic piece out. Put it back together and let it dry. The apply the auto adhesive and put the rubber strip back on. I honestly have no idea if this will work on the 2Gs, but that is how I did mine on my car. Good luck.
Eric
13.4 @ 102.9
Big 16G @ 19 psi
Old 05-29-2002, 11:56 AM
See now that wasnt so hard was it?? Just kidding man, thanks a lot I appreciate, Im going to see if I can do this, but it sounds a little complicated so I might not want to mess with it, but I appreciate it though thanks!!
