| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Box Stuffing / Poli-Fil
Before I build my box, which would be MASSIVE for a tinyass honda civic, (4 cu.ft.), I'd like to consider having atleast some trunk space. I hear that you could use poli fil, about 1 pound per 1 cu.ft. of space you got, but how much space does that make the subs "see"? or is it that using 1 lb of polyfil will make the speaker "see" 1 cu.ft. of space? Also, is it as good as just making the damn box to its actual size rather than downsizing it and putting in stuffing? thnx.
Re: Box Stuffing / Poli-Fil
I believe you're supposed to use 1 pound per cu. ft. and that makes it see a little more space... but I don't think it makes it "see" the 1 cu. ft... I understand what you're saying though.
When I looked on the internet, I couldn't find a lot of info on using the stuff. It can't be nearly as good as actually having the correct size box. |
Re: Re: Box Stuffing / Poli-Fil
Well i have a bag of poly in my box right now.I didn't need it but i used it.It did make my subs hit alittle harder on a meter i had 1db+ with the fill so take it as i.
Scoot |
As far as I know, you shouldn't purposely make your box smaller and then use polyfill, you'd be much better using the correct box specs. Polyfill is only if you're off by a few cubic ft. or something small like that. I'd double check with someone else though.
My speaker are in the right box.I just used a bag of poly to see what it would do.
Scoot |
This may help, from another forum......
