Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-05-2005, 11:32 AM
Corkster52 Corkster52 is offline
Angry Fuel gage inaccurate
The fuel guage on my '97 2500 is really messed up. From reading full til empty is only about 11 gallons used (and I have a 35 gallon tank). I went to the Dodge dealership this morning and they said it would be around $300 for the sending unit and another $300 for labor to install it. That is an awful lot of money for a fuel guage issue. My question is, will the low-fuel warning light on the dash work as an indication of how much fuel I really have left, even thought the needle on the guage is very apparently wrong?
Old 11-06-2005, 01:30 PM
JDusen4211 JDusen4211 is offline
Send a message via AIM to JDusen4211
Re: Fuel gage inaccurate
no sure if the fuel warning light will work, but i doubt it. but you can put the sending unit in yourself to save some $$. the hardest part is to drop the tank and the rest is gravy... should only take a couple hours if its your first time. just make sure u have very little gas in the tank when you drop it... it makes life much easier. i would also try to find it somewhere other than the dealership... it should be much cheaper. you could also check around to see if you can use a universal sender that would be cheaper as well... but when it comes down to it, i would go ahead and buy the proper parts since your truck isn't a $500 work truck... especially if you plan on keeping it for a while and don't want to have to redo it 5x.
