Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-05-2005, 10:52 AM
TonyP TonyP is offline
92 Rear Disk replacement
I'm replacing the rear disk brakes on my 92 Cutlass Supreme and I can't get the piston back in. Does it screw CW or CCW. Everything is pretty corroded so I've also tried to change the caliper andf I can't get the brake line off.
Can't even put the old pads back in to get to a shop. What can I do? Help!!!!
Old 11-05-2005, 11:54 AM
maxwedge maxwedge is offline
A990 racer
Re: 92 Rear Disk replacement
Do you have the proper tool? You will need to put pressure on the piston as you turn it in clockwise.
Old 11-05-2005, 01:06 PM
Re: Re: 92 Rear Disk replacement
Yes, I have the tool but it seems to come out when I turn it clockwise. Are the 2 sides of the car different? I'm doing the driver's side.
Old 11-05-2005, 02:45 PM
A990 racer
Must keep inward pressure using tool, should be cw, try the other way just keep making up the tool to keep the pressure on the piston, it's always a pita. You ca easily see if it starts to go inward.
