Which eclipse to buy?
Alright i have been saving money for a while and i have decided to buy and eclipse. I really like the body style of the 3g eclipses. I am eventually going to buy turbo for it, but i am wondering wich eclipse i should buy, the v4 or v6, and why?
Re: Which eclipse to buy?
4cyl. the 4cyl engine is a very good powerplant to turbo. you will not have to do any internal engine work unless you plan on running more than 15-16psi. its a very strong engine when it comes to boosting.
the v6 is an 'ok' engine. if you wanted to run more than 8-10psi, you would need to replace the pistons with forged pistons. |
ok thanks, but how much do u think the turbo would add up to price wise including all the essentials needed to run it. how much for the v6 and then how much for the v4.
Re: Re: Which eclipse to buy?
for the v6, the option of piecing together a kit is not a very good one. in the end, you would come out cheap just buying a kit. tearstone also sells a kit for the v6. in summary.... 4cyl = $2000-$5000 depending on your needs v6 = $5000+. |
Re: Re: Re: Which eclipse to buy?
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads. |
alright ic thanks alot for this information. If i got turbo on the v6 though the gain would be alot better though right?
Also wat is the differnece in speed on a stock v6 and v4 And then between a modded v6 n v4 after like turbo and etc. |
I was just on the tearstone website they sell a kit for the v6 for 4,500. Would u need to upgrade anything else in the car if u baught that kit?
4cyl = a turbo kit running 14psi(stock engine internals) will yeild you around 300whp. v6 = a turbo kit running 8-9psi(stock engine internals) will yeild you around 300whp. as you can see, they are pretty you can get about the same amount of power out of both stock engines. but the 4cyl is cheaper. Quote:
ok thanks this is really helpfull. I have one more question. What is the differnce between the two kits for the v4? Can one handle higher psi?
Plus, I'm sure they can do a DOHC 4g63 head conversion on the 2.4L 4g64...they did it successfully on an NT 2g spyder. But like everyone already said, the i4 is a stronger block for boost.
![]() Don't act like you don't love it.
503/2000 |
if you have questions that you don't think that we are answering good enough, you can always send an email to [email protected] and ask Russ(tearstone). |
also, it's not a "V4", there haven't been any V4's since the 60s. Its an inline 4 or I4
Dr. Disque - Current cars: 2008 BMW 135i M-Sport 2011 Mazda2 Touring Past cars: 2007 Mazda 6S 5-door MT 1999 Ford Taurus SE Duratec |
thanks everyone for the help. I guess ill be getten a gs soon. And probly the cheaper turbo kit cause it seems like a better deal then the enhanced one.
