Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-05-2005, 06:33 AM
crabby760 crabby760 is offline
What SET UP IS BEST!!!!!!!!!
b18c1 gsr block stock with built b16a head?
or built ls block for ls/vtec... with stock b16a head..?
just curious wich woudl put out more power...?
Old 11-05-2005, 12:37 PM
Kven's Avatar
Kven Kven is offline
Re: What SET UP IS BEST!!!!!!!!!
gsr block with built b16a head.
key to more hp all-motor is in the head....
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 11-05-2005, 04:18 PM
JustaSolVTEC JustaSolVTEC is offline
Send a message via AIM to JustaSolVTEC
it really depends on the build.
CR-VTEC > both
Old 11-05-2005, 04:20 PM
Kven's Avatar
Re: Re: What SET UP IS BEST!!!!!!!!!
CR-VTEC > both
yea right...reason being, compression ratio...
1988 Honda CRX DX
Old 11-05-2005, 04:26 PM
these were my ideas..?
ls block... type r pistons/rings... ls rods wit arp rod bolts... acl bearing kit... type r oil pump... with b16a head with type r cams /camgears TO START!!!!!!!!
or gsr stock block with b16a ported & polished with type r cams/camgears & complete PORTFLOW Valvetrian...?
right now i have the complete sir 2 jdm b16a motor .... should i keep that and just build both the b16 block and b16 head.. or nah??? ideas people...
oh and wich tranny would be best after i'm done BUILDING...
ls b16 or gsr..? has ls now laggish
Old 11-05-2005, 04:32 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
B16 has shortest gearing. ITR tranny has LSD. My choice would be between those two.
Empty Pockets Racing Member #1
Old 11-05-2005, 06:29 PM
Re: Re: Re: What SET UP IS BEST!!!!!!!!!
using stock B20 pistons....maybe. built, a CR-VTEC will make more power than both.
Old 11-05-2005, 09:42 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
all motor maybe, but b20's aren't good for boost....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-06-2005, 12:59 AM
how many B20s have you boosted? B20s are fine for anything if you have a good tuner.
to those talking about the B20 and CR-VTEC, how many of you actually own one?
Old 11-06-2005, 05:33 AM
Kven's Avatar
Re: Re: Re: Re: What SET UP IS BEST!!!!!!!!!
if they were both built; a CRVTEC will be the same as a LSVTEC because youll be able to bore out/resleeve the LS to the same size as the CRV block.
1988 Honda CRX DX
Old 11-06-2005, 05:40 AM
Kven's Avatar
how about this; GSR Block with the p30 b16a pistons, the built b16a head, and b16 or ITR transmission.
If your car is light, you can probally keep it 1.6L
1988 Honda CRX DX
Old 11-06-2005, 05:45 AM
Kven's Avatar
If actual CRVs count, yea i had one for a bit. you dont need to own one to know about them though; its pretty much a LS block with a larger bore and siamese sleeve design. i do know some people who are running them though with no problems(except for one guy who over-revved his motor and had valve-piston collision; B20-VTEC setup w/ GSR head).
1988 Honda CRX DX
Old 11-06-2005, 12:38 PM
Re: Re: Re: Re: Re: What SET UP IS BEST!!!!!!!!!
you could, but then with the money spend boring an LS block to 84mm, you could add more mods to the CR-VTEC. but hey, what do I know? I've only had one for almost two years.
Old 11-06-2005, 01:34 PM
my car is a 96 integra
so over all... everyone is saying go b20 block with b16 head?
and a b16 or gsr tranny?
wat internals are best for the b20
Old 11-06-2005, 01:38 PM
with me having a integra...
could i just build the whole b16 block and head.... and still be fast or no...
do i need to go b20 vtec?
just curious if there's anyway to make a all motor b16a + nitrous fast in a 94 up integra ?
