Old 11-05-2005, 05:02 AM
Cmdridq Cmdridq is offline
Clutch question
I've got an 89 Civic 4WD wagon with a manual tranmission. If I'm cruising at a constant speed, say 40 mph, and then push the gas pedal down, the engine will rev up before the car actually accelerates, as if I was stepping on the clutch at the same time. It only does it under hard acceleration. Other than that, it seems OK. What is happening?
Old 11-05-2005, 03:28 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Clutch question
sounds like clutch is slipping.
have you tried adjusting the clutch cable ?
Team Lonely Drivers
Old 11-05-2005, 03:47 PM
No, not yet. I've never done that. Can you easily tell me how to check it?
Old 11-05-2005, 09:13 PM
Re: Clutch question
pull up on the clutch cable, at the clutch arm turn the knob and tighten it till there is very little play in the arm
Team Lonely Drivers
Old 11-06-2005, 03:09 AM
CrxFreak91 CrxFreak91 is offline
Re: Clutch question
or put a new clutch in
