Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 11-05-2005, 02:50 AM
andyhs andyhs is offline
Lightbulb Modifying Ignition Timing
Hi guys,
I have an old 323 '87. And I want to modify the ignition timing system, instead of moving/rotating the distribution cap, can I modify it to adjust it electronically ?
I have an idea, I don't know is it possible or not, to delay the signal from the cdi to ignition coils, and change the spark cable sequence.
Here's my explanation, if I delay the signal, it means "retard", but it is for the cylinder that will be combust, but it is "advance" for the next cylinder. so if I switch the spark cable, is it possible ?
And if it's possible, any of you have an idea how to delay it with a very simple device ?
Thank you in advance.
Old 11-05-2005, 05:53 AM
Flash75 Flash75 is offline
AF - Advisor
Re: Modifying Ignition Timing
I don't understand your point, are you trying to be smarter than than the engineers that built the car?
Clifton
Old 11-05-2005, 06:02 AM
Re: Re: Modifying Ignition Timing
Clifton
No, you missed my point.
On new car, the ignition timing is set by ecu. My car still using manual ignition timing to set. I would like to put something so it can be adjust electronically.
Do you have any idea ?
Thanks
Old 11-10-2005, 03:32 PM
AF - Advisor
Electromotive makes direct ignition systems with provisions for timing adjustments. The units I have seen have a trigger on the front pulley and the distributor is eliminated. Do a Google search on Electromotive Ignition. Here is one example I found with a quick search.
http://www.racetep.com/hpx.htm
Clifton
Old 11-11-2005, 08:35 AM
Thanks, I'll check it out.
Regards,
Andy
Old 11-11-2005, 11:45 AM
mazdatech177 mazdatech177 is offline
yikes
Old 11-11-2005, 01:40 PM
mazdatech60's Avatar
mazdatech60 mazdatech60 is offline
just switch the wires 90 degrees clockwise then go 2 teeth on the distributor the other way, it will run awesome
Old 11-12-2005, 07:09 PM
AF - Advisor
mazdatech60, You said.
"just switch the wires 90 degrees clockwise then go 2 teeth on the distributor the other way, it will run awesome"
If I understand your comment, you suggest moving the ignition wires 90 degrees clockwise and then move the distributor drive gear two teeth counter-clockwise. Moving the drive gear two teeth will also move the distributor rotor counter-clockwise.
Assume you have set number one cylinder to TDC compression stroke. Assume that the normal position for number 1 cylinder is at 12 o'clock. The rotor should also be at 12 o'clock. After moving the ignition wires 90 degrees clockwise the number one cylinder wire will be at 3 o'clock. The rotor is still at 12 o'clock. The drive gear is moved 2 teeth counter-clockwise. The rotor also moves counter-clockwise. Lets say that two teeth moves the rotor 80 degrees, (I just counted the teeth on a distributor drive, not Mazda, it has 9 teeth). The rotor is now near 10 o'clock, but it needs to be near 3 o'clock for the engine to run. The ignition timing would be almost 180 degrees off.
Clifton
Old 11-14-2005, 07:20 AM
you are looking way to deep into this, what i said was a joke.
the ecm will adjust the timing to what it needs anyways.
Old 11-14-2005, 08:01 AM
AF - Advisor
Ok, No problem, I realize the ecm will adjust as needed. Since we don't know the people posting, it's sometimes difficult to determine if they a serious.
Regards, Clifton
