Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 11-04-2005, 09:45 PM
Crx-me Crx-me is offline
Knock Sensor
hey i put in the pr3 but i cant find the freakin knock sensor!! anyone know where it is? i got the b16a1
Old 11-05-2005, 05:36 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Knock Sensor
behind the block, above the oil pressure sensor. jack up the car and look.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-07-2005, 10:36 PM
alright i had to splice in the wire to the knock sensor because the harness did not hook right up. kinda fishy but a friend said it would be ok. unfortunatly its still saying knock sensor error. ive checked the wiring to the computer 10 times. is there anything i could have missed?
Old 11-07-2005, 11:07 PM
AF - Advisor
Re: Knock Sensor
been a while since i had my b16 EF, but, i believe the knock sensor runs to B19. check it for contiunity.
Old 11-08-2005, 02:34 AM
InJ3cted's Avatar
InJ3cted InJ3cted is offline
Send a message via AIM to InJ3cted
are you obd1 or pre obd?
Black 1990 CRX Si FI d16a6 R.I.P
1995 DC Integra LS jdmb18b w/ ys1 trans SOLD
1990 EF civic Si sohc ninja project Traded
1992 EG vx hatch sohc turbo/gsr swapped SOLD
1992 DA9 obd1 love, non-vtec love project
Old 11-08-2005, 05:33 PM
its obd0, im wondering if the guy i bought the car informed me wrong about the engine, maybe its not a b16a1, the block says b16a so i know its jdm but how do i know which version it is. still that might not even make any difference from what ive heard. anyways its still flashing code 23 knock sensor error and i cant figure out why
Old 11-08-2005, 06:29 PM
AF - Advisor
Re: Knock Sensor
b16a1 is the european b16. b16a is the JDM b16. the obd0 b16 is a cable tranny b16. check contiuty from the ecu to the knock sensor to make sure the line is not open and to make sure it is properly in the right place.
Old 11-09-2005, 03:31 PM
Re: Re: Knock Sensor
well everythings hooked up right, i think i have an actual knock problem. my valves are making all kinds of clicking noises and when you get on it theres a very irregular click like i have a bent or broken valve. i need to get a book for the engine, i was thinking a Haynes book but im not sure what vehicle to get it for. is it the 88-91 integra?
Old 11-16-2005, 09:39 AM
illack91 illack91 is offline
Re: Re: Re: Knock Sensor
i have the same problem i put a obdo b16a in my integra everythings hookd up right and when i open it up a wierd tickin noise comes on and on low rpms i sputter like im not getting enough gas or spark. it also stops sputtering for a while and runs fine im running 93 octane but i also have a pr4 ecu and wiring harness can someone help me out
Old 11-18-2005, 03:02 PM
Re: Re: Re: Re: Knock Sensor
yea it turned out to be spark knock, all you have to do is retard your timing untill it goes away, or get some octane booster or both.
Old 11-22-2005, 02:25 AM
Przemir4g Przemir4g is offline
i also change in b16a1 obd0 /europe/ PW0 ECU to JDM PR3 - 2 weeks I was faithing with ecu error and i buy new PW0
fee days ago my friend told me that i have to use special cable - mayby U can trie
I hope U will do IT !!
Old 11-22-2005, 06:33 PM
Re: Knock Sensor
wait wait what? your saying a need some kind of adapter? if this worked for you please send me some info on it. i was just gonna suck it up and buy the sensor this weekend so let me know
Old 11-23-2005, 01:41 AM
Re: Knock Sensor
not adapter - normal wire will toke supertension from the rest of wires close to ECU
I use 3 knock sensors / I was thinking it is a problem/
but for me the bigest problem was gas - in poland we have very shitty gas /in 95 knocks ware all the time in 98 wen i was running slowly was ok when I start to take more than 7k rpm - 23 error on ECU
why U wont to use pr3 ecu? vtec is faster/round 5200-5300/ than in pw0/5500-5600/on clock is ther more? on my ass dyno car rides the same i whas thinking that thanx to ecu i will have more power my bad/
