Old 11-04-2005, 09:24 PM
h22hatch91 h22hatch91 is offline
hopefully the last tranny question??????
ok i have another question involving trannys......ok here it is.......ok in my 91 hb i have a jdm b16 from a 90-93 integra and the tranny code is an A1 , the question is if im putting in a 90-93 ls tranny to replace the a1 do i need to get a different clutch or can i use the same one??? i have herd all storys like- 1) i just have to change the flywheel 2) it will match right up and 3) that it will match right up only if its a 90-91 matching up with a 90-91 or a 92-93 matching up with a 92-93 .................now the 3rd one sounds right but i wanna now if thats for sure or if not which on it is if any???????????? .............like always thanks for the help b/c u guys always do..........U GUYS R FRIGIN AWESOME .......
Old 11-04-2005, 09:42 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: hopefully the last tranny question??????
now idk if you want to listen to what i know because as you said im not mechanically inclined. but a A1 is a usdm ls tranny, not jdm. flywheels are all the same from 90-01 so theres no difference.
pressure plates: 90-01
clutch discs: 90-91 and 92-01
throwout bearings: 90-93 and 94-01
that means that the clutch is different from 90-91 and 92-93 because of the clutch disc. so if the tranny you get is from a 92-93 you will need a new clutch disc. if hte tranny is from a 90-91, you can use your same clutch disc.
i have a A1 in my car, i run a 90-91 exedy clutch
Team Lonely Drivers
Old 11-04-2005, 10:02 PM
kinda a dumb question........but is there a way for me to see what year my a1 is?????? thanks for the help, i wasnt tryin to be a dick about u not being mechanically inclined bc obviously u know alot and u have helped me alot and i appreciate it ......thanks man sorry for being an ass......
Old 11-04-2005, 11:12 PM
i have no idea how to determine the year of the tranny.
my guessing is that its a 90-91 but thats just a guess. only way would be to try put your clutch plate on the tranny and see if it fits, im pretty sure the 92 and up trannies have a bigger input shaft
Team Lonely Drivers
Old 11-05-2005, 09:00 AM
so as long as i find a 90-91 ls tranny i will be good right?????????????
Old 11-05-2005, 03:31 PM
well if your A1 is a 90-91. the only problem with the A1 trannys is that i havent really been able to find any info on it.
but i think the 90-91 came with the S1 and A1. and the 92-93 came with the YS1. but again this is just a guess
Team Lonely Drivers
