Old 11-04-2005, 08:09 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
Question Which spark plugs do i use for...
my d15b vtec swap... but im still running my crx si intake manifold and distributor. So I would use the crx si plugs... correct?
Old 11-04-2005, 09:10 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Re: Which spark plugs do i use for...
ZFR6F-11 is the correct plug for D15B VTEC... Good luck finding them locally... I had to buy mine from www.sparkplugs.com... But they are one degree colder, or hotter (cant rem which way it goes) than the D16Z6, which is ZFR5F-11... Dont think the intake manifold has anything to do with it... But maybe the distributor does... Im not sure...
Old 11-04-2005, 09:20 PM
Well, the car is not running properly with the stock d15b vtec plugs tha are in there now, so I'm assuming i should use the si ones? any one else?
Old 11-05-2005, 12:16 PM
Swap them out for your old ones... See if that works... But I doubt it... Its probably a wiring problem... Also check and see what plugs are in there... Mine where correct, but I replaced them anyways... But being a used engine, they may not even be the correct plugs...
Old 11-05-2005, 09:29 PM
justin476 justin476 is offline
sorta off topic..but what plugs would be good for my dohc zc?
Old 05-05-2008, 07:07 AM
slyw/fbpsi's Avatar
slyw/fbpsi slyw/fbpsi is offline
The correct plugs are ZFR6J-11. I should of looked at my cam cover instead of following what I read on the internet. Now, my check engine light comes on anytime I want to take it easy on my car. ZFR6F-11 will have you running too lean.
Sly
Gotta catch me first
Old 05-05-2008, 12:27 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
I would hope by now he has this figured out.
Tony
91 Civic Sedan DX - Stock 287k Miles
