Old 11-04-2005, 05:02 PM
snubber snubber is offline
center terminal in 2002 cavalier headlight socket melting
Does anyone know what the function of the center terminal of a 9007 headlight socket fuction is. Is it a ground or power. does anyone know what would cause that terminal to melt?
any help would greatly be appreciated
Old 11-05-2005, 04:11 PM
quake61's Avatar
quake61 quake61 is offline
Re: center terminal in 2002 cavalier headlight socket melting
could be a loose contact or the bulb gets too hot ( not stock bulb)
anyway autozone sells the connectors change it and make sure all grounds r tight
Old 11-06-2005, 08:46 AM
Yesterday i replaced the socket
I replaced the socket again and used the original bulb that came with vehical i also used dielectric grease on all three terminals. I will see how long this will last. Thanks for your reply
