Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 11-04-2005, 04:56 PM
TheBrettster TheBrettster is offline
AF Premium User
99 2.2l Problem
I notice when I go 30 + or stop and go traffic i will start to feel really hot air come threw my vents and by the gas pedal. I dunno whats causing it either .
Old 11-05-2005, 05:53 AM
Getsum Getsum is offline
OK, I'll bite, have you checked the position of your heater switch? If it's in the floor vent position, that'ss where the heat will come out. If you cant contro where the air comes out (either vent/defrost/or floor heat) then you probably have a vacuume hose leak behind the heater contro panel. The reason it happens after 30+ miles is because thats about when your truck heats up and the hot water flows through your heater core. Try lowering the temp if nothing else, then you'll have nice cool air blowing on your legs. Hope this helps. Lee
Old 11-06-2005, 11:59 PM
AF Premium User
humm
The air is shut off. Everything is shut of. AC , VENT everything.
Old 11-07-2005, 08:37 AM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
Re: 99 2.2l Problem
I believe that there should always some airflow. Yes, even in the "OFF" position. I have the same thing on my s-10. I even noticed it a bit on my Hyundai also, i'm thinking its to help with the cabin air, keeping it moving. because you're not going to drive with the windows open all year (depending on where you live).
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 11-08-2005, 12:08 AM
AF Premium User
hum
No the air is very hot. It almost melts my shoe. Well not really but its not normal. I have a 2001 Blazer and never felt it.
Old 11-08-2005, 09:09 AM
mike1224's Avatar
Re: 99 2.2l Problem
i have no idea then, i've noticed warm air but not hot air. sorry man
2002 Chevy S-10 ZR2
