Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 11-04-2005, 02:29 PM
bigal54 bigal54 is offline
Question Door panel removel
Help!! can anyone tell me how to remove a back door panel on a 2000 Ford Focus. The back power window is broke. If anyone has a diagram that would help alot. Thanks
Old 11-07-2005, 04:58 PM
smugpuff smugpuff is offline
Re: Door panel removel
If you ask nicely at the dealer they will likely give you a copy of the illustration in the shop manual. Your other alternative is to go to Helm.com and spend the $120 for the shop manuals. Very handy item to have if you are doing a lot of your own work on the car. I'm waiting till my warranty runs out before I buy mine. Good Luck.
Old 11-07-2005, 07:22 PM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
no its not you can get a Haynes manual at pepboys or advanced ouato/autozone for like $40
i dont know ANYONE that actualy owns the shop manuals
Old 11-07-2005, 09:04 PM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
I'm with ZX2...got my Hayne's Focus manual at PepBoys for $15. It's not for really intense repairs or diagnostics like a shop manual would tell you, but it's great for simple stuff like this. Great investment, especially if you work on your own car a lot.
-Chuck
Old 11-08-2005, 01:10 AM
dazada's Avatar
dazada dazada is offline
Send a message via Yahoo to dazada
Post
1.) Pry out from rear edge of sail panel (the triangular piece of trim by the window) to release 2 retaining clips, and remove panel.
2.) Pry off screw cover in door release trim (the trim surrounding the door opening latch) and remove 1 phillips (or Torx T20 screw.) Starting at the front edge, pry door release trim to release 2 plastic clips and pull forward toward rear of vehicle to release 1 plastic clip. Disconnect wiring harness (if equipped). Remove trim.
3.) Insert a small, flat blade screwdirver into bottom edge of door pull trim (the trim on the door pull). Pry out trim, grab and pull trim to remove.
4.) Remove 2 phillips screws (1/4" in some models) exposed by door pull trim removal.
5.) Remove 6 Torx T15 (or Torx T20) screws from edges of sides and bottom of door panel.
6.) If equipped with manual windows: With the window crank in the down postion, use a shop rag with a "shoeshine" motion to release "C" clip on rear of window crank and remove crank. You need to get the rag between the base of the handle and the plastic gasket for it to work. (Use some muscle...this is not an easy task.)
We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, with so little, for so long, we are now qualified to do anything with nothing.
Old 11-08-2005, 09:25 AM
Well ZX2 let me be your first. I've owned the shop manuals for my '87 CRX, '92 Cherokee, and when my warranty runs out, my '03 Focus. My problem with Haynes and Chilton manuals is for a lot of the repairs they don't get specific enough.One example I can think of in the Chilton Manual I had for the CRX was "Remove water pump, then gasket." Not helpful at all in that case. Kudos for Daz for actually posting something more useful than mine. For stuff like panels though, I would say that the Haynes manual should fit the bill nicely.Welcome to the forum bigal.
Old 11-08-2005, 11:01 AM
Re: Re: Door panel removel
Thanks for the info.This site is great!
Old 11-08-2005, 11:03 AM
Old 11-08-2005, 11:09 AM
HEY THANKS !! You guys are great!
Old 11-08-2005, 11:13 AM
Thanks! Because of all you guys this is a great site.
