Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-04-2005, 02:15 PM
pau143 pau143 is offline
harmonic balancer
Are the threads right handed or left handed on the harmonic balancer bolt? If I'm facing the front of the engine the pulleys does it come off counter-clockwise or clockwise?? Help please..
Old 11-04-2005, 07:05 PM
maxwedge maxwedge is offline
A990 racer
Re: harmonic balancer
Counter clock wise, you probably will need a puller designed for this also, especially on the 380011.
Old 11-05-2005, 09:30 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Depending on the year, you'll either need a puller, or a BIG breaker bar. SOme of the older 3800's had a crank bolt torqued to 240 ft/lbs, then the balancer slides off. The other style isn't torqued as tight, but requires a puller to remove. Look for the 3 threaded bolts the puller mounts into. If your balancer has the 3 holes, you need a puller. If your's is smooth on the front, you need a BIG breaker bar.
Old 11-05-2005, 12:00 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Re: harmonic balancer
Originally Posted by richtazz
a crank bolt torqued to 240 ft/lbs, ..............
And 3 gorillas to help you turn the bar and stop the flexplate from turning at the same time!!
Old 11-05-2005, 12:48 PM
A990 racer
Impact gun all the way, problem is retorquing on the way back together. Need 6mm 3" bolts for the puller to work.
Old 11-05-2005, 10:29 PM
Got it off with a breaker bar and extra leverage bar..Thanks for all the help!! Car seems to be starting fine now since I replaced the crank sensor...You guys are great!!!
Old 11-06-2005, 08:26 PM
stangdrvr stangdrvr is offline
I use an old trick that works like a charm to get the super duty crank pulley bolt out...
-take off the small plastic inspection cover from the trans, exposing the flexplate.
-clamp a vice grips onto the side of the toothed outer ring of the flexplate.
-using a 1/2" drive breaker bar, the crank bolt will break loose.
This was after fighting for hours with a high powered 3/4" drive impact gun with no luck.
