Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 11-04-2005, 01:47 PM
dss56 dss56 is offline
98 durango shift indicator
got a 98 durango and the other day i noticed the shift indicator is way off wont move ontil its in drive and says im in reverse/park. what is the best way to get to this and fix it? what has to be removed?
thanks
Old 11-04-2005, 04:42 PM
WPAGEJR WPAGEJR is offline
Remove The Front Of Your Dash. You Will Have To Put The Truck Into 1st Gear In Order For The Dash To Clear The Steering Column. It Is Fairly Easy, It Should Just Pull Right Out. After That Remove You Gauge Pod. I Believe It Is 4 Phillips Screws. You Will See On The Back Of The Gauge Cluster How To Adjust The Shift Indicator. Let Me Know How It Goes
Old 11-04-2005, 06:56 PM
shift indicator reply
do i take the front off where the guages are? does it just pop off or pry off are u sure there are no screws>
thanks for the reply
Old 11-05-2005, 07:45 AM
you need to take the trim that goes around the gauge cluster off. that should just pry off. you should be able to pull it off without prying it. then you will need to take the gauge cluster off. that has 4 phillips screws. you will see them once you have removed the trim around the cluster.
Old 11-06-2005, 11:54 AM
Re: 98 durango shift indicator
believe it or not there was an adjustment a big white nylon knob to adjust the shift indicator. Noticed this about 1/2 hr after playing with the little cable connectec to the indicator. adjusted it and all is ok.
thanks for the responses and help.
Old 11-06-2005, 12:02 PM
believe it or not there was an adjustment knob a big white nylon knob to adjust the shift indicator. Noticed this about 1/2 hr after playing with the little cable connected to the indicator. adjusted it and all is ok.
