Old 11-04-2005, 12:19 PM
Mrock Mrock is offline
Send a message via AIM to Mrock
ZC CRX Advice..where next?
Hey guys. It's been a while. Last time I posted on autmotiveforums.com I think I was scraping for just a little bit of cash to put a new engine in my CRX. I am now in slight better shape, and beginning my second year in the army. Here's my dilemna..
I put a ZC in my CRX- bought it off a buddy of a buddy basically, who was a mechanic, that did the work..but never installed it, as he got into Chevy's again. The ZC specs are in my signature..
That's about all I can recall off of my head. The engine is sitting in my 91' CRX DX back home, all bolted up, awaiting a new ECU, and new radiator, before I can see if it'll even run. It turns over, but the ECU I had bought was a dud. It's basically in OK condition. I was going to turbocharge it, with a small amount of boost (I wanted like, 6-8 lbs of boost with AEM EMS, possibly)..due to the fairly high comp pistons. I figured it'd be a pretty damn nice setup.
The issue here though, is that setup was created with an average amount of money available..it was the best setup I could afford at the time. Me being the car junky I am, I always want more. I am now on active duty, and am not paying rent, or basically any bills with the exception of one or two small ones. I have been wondering whether I should contemplate selling the whole CRX project, just the engine, or what. I have always wanted to build a fully built from scratch engine that would dominate when on boost. Now that I have the capabilities (granted it'd take a while..)..should I?
I guess the issue is, I don't know many people who would buy an engine, and personally go over to remove it and take it home. I am not able to be there, so I have my family back home to accept the money but that's about it. Keep the ZC, maybe build a second (tougher..sleeved) ZC block, or just start from scratch?
I apologize for taking everyones time..but I have been wondering about this a lot recently so I'm curious what you all have to say. Later everyone..
ZC powered '91 CRX...JE 10:1 pistons, Crower rods, Bullfrog cams, Throttle body bored by Gude, Port and polished head, AEM adjustable cam gears, 340cc injectors, MSD SCI ignition, Cold air intake, clutchmaster stage 2 clutch, aluminum flywheel/heavy duty pressure plate, zex nitrous kit.
Waiting to arrive (and install, to get this baby running!)
Walbro fuel pump, PWR radiator, PM7 ECU
Look out, I can run 17's allllll day.
Old 11-06-2005, 03:25 AM
CrxFreak91 CrxFreak91 is offline
Re: ZC CRX Advice..where next?
so what is actually your prob
Old 11-06-2005, 05:00 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
so you asking us if you should build a motor from scratch up?...its always best to build a motor from the ground up long as everything is done right...its to bad you didnt know what you wanted to build...a lot of people usually build up b20 and i have a lot of those parts on ebay right now...I just gave up the project and gonna go another way...in the future I probably be dropping in a k series motor in my rex once everything all said and done...so need to tell us a lil more and what your goals are in building it.
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 11-07-2005, 12:15 AM
the stock zc will handle a turbo pretty decent seen one run bout 13.00 in quarter with 7 psi. mostly stock motor. i had one with nitrous 70 shot ran 13.2
