Old 11-04-2005, 10:25 AM
robroy55 robroy55 is offline
Why missfiring only at acceleration only??
Sorry to keep bugging you guy's but my 2002 24 valve only runs ruff at idle and when full acceleration. AutoZones codes read missfire on 1 and 3 cyl.
Trying to learn all I can so I can stop bugging all you helpfull folks !!
Rob Roy
Old 11-04-2005, 03:17 PM
Psychopete Psychopete is offline
Re: Why missfiring only at acceleration only??
Rob Roy
Next step is to check the conditions of plugs 1 & 3.
Pete
Old 11-04-2005, 07:23 PM
~manuel~ ~manuel~ is offline
Rob Roy
just replace the plugs in those cylinders to see if it helps.ive seen normal looking plugs causing misfires before
Old 11-04-2005, 09:02 PM
24 valve fireing order??
I have spent hours on the internet trying to find info on the fireing order AND which side of the engine (front 3 or back 3) spark plugs are for cylinders number 1 and 3. on my 2002 24 valve engine.
Boy, I sure hope I find a Haynes manuel soon for this car so I can stop bugging all you guys with these basic questions.
Thanks again for all responces and help !!!
Rob Roy
Old 11-05-2005, 07:51 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
The firing order for the 2002 Taurus with 4-valve per cylinder 3.0 liter V-6 is 1-4-2-5-3-6.
I believe that cylinder #1 will be the cylinder nearest the firewall at the belt end of the engine (left rear as looking at the engine from in front of the car). I'm not positive on that. If your car has the original plug wires, the wires are probably labeled for the cylinder they go to.
-Rod
Old 11-05-2005, 09:19 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Here is a link to All data DIY repair info online sub.
It covers everything on your car. 24.95$ a year but it is better than 10 haynes manuals. And you can get it in 10 minutes. Has all recalls and tsb and all repair info.
http://www.alldata.com/products/diy/index.html
MT-2500
