Old 11-04-2005, 10:21 AM
Turbogp Turbogp is offline
Send a message via AIM to Turbogp Send a message via Yahoo to Turbogp
Question 1999 Grand Am Horn Not Working
Hello everyone,
I have a 1999 Pontiac Grand Am SE with the 3400 motor. I have a problem with the horn not working from the steering wheel column and was wondering if anyone could help me fix it. I know the horn does work because it sounds off with my alarm. It just will not work when I press on the steering wheel. If anyone could help me, I would be thankful.
Thank you,
Jaime
Old 11-04-2005, 04:37 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1999 Grand Am Horn Not Working
The horn activates by supplying a ground to the horn relay. Since the horn works with the alarm, the problem goes back to the steering wheel. When the horn button is pressed a ground is supplied via a slip ring to the horn relay. So the horn button is probably worn out or defective or the slip ring is bad. Also, try blowing the horn while you turn the steering wheel in different directions.
Timeslip 08/12/06
AF Community Guidelines
Old 11-09-2005, 03:41 PM
99gadriver 99gadriver is offline
I have the same problem, and I know the slip ring is bad. Does anyone know where I can get a new one. I've been searching everywhere online and can't find the part. I don't mean to hijack the thread, but I'm having the same problem.
Old 11-09-2005, 08:43 PM
BNaylor's Avatar
Re: Re: 1999 Grand Am Horn Not Working
Send a PM email to Richtazz. He's an ASE Certified Parts Specialist and specializes in GM cars. If he can't get you a part number and where to get it then no one can. Good luck!
Timeslip 08/12/06
Old 11-09-2005, 10:35 PM
97grandamld9 97grandamld9 is offline
Banned
is a slip ring the same thing as a clock spring?
Old 11-10-2005, 11:01 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Your part # is 26099571, and it's part of the turn signal cancelling cam. It's a dealer only part, and runs $18.31 retail.
Old 11-10-2005, 12:30 PM
Thank you very much richtazz! And thank you bnaylor3400 for pointing me in the right direction.
Old 11-10-2005, 04:18 PM
richtazz's Avatar
no problem, Bob and I work well together.
Old 11-13-2005, 04:04 PM
Banned
does this part work the horn, i was told it is activated by a clock spring (which is in the $120 price range) on my car when you turn the wheel and press on the horn you can get the horn to work sometimes and if you push on the horn hard it will sometimes work. Do i have the same problem as the other users (18 bucks is sure better then $120)
Old 11-16-2005, 06:16 PM
Banned
anyone?
Old 03-27-2019, 03:33 AM
clintluna clintluna is offline
My car will ONLY HONK when I TURN WHEEL TO RIGHT.....Anyone Know Why?!?!
