Old 11-04-2005, 08:45 AM
dnakohrmann dnakohrmann is offline
leak at front of driveshaft
I just changed the fluid in the transfer case and now I have a leak at the front of the rear driveshaft right at the u joint, but there is nothing on the outside of the shaft coming out of the transfer case, it is like its coming out the end of the shaft.
Any ideas why this is?
Old 11-04-2005, 09:59 AM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: leak at front of driveshaft
Can you post any pics of it? It would be more helpful to actually see for ourselves what is going one.
1969 Olds Cutlass
1985 Olds Cutlass
2000 Ford Ranger
2001 Jeep Cherokee Sport
Old 11-04-2005, 11:56 AM
2000CAYukon 2000CAYukon is offline
Check the vent tube on top. If you overfilled it could be leaking out the vent tube.
//2000CAYukon
Old 11-04-2005, 12:28 PM
I dont think it is the vent tube because there is no leaks on the case itself. There is nothing on the output shaft of the transfer case it looks like it is coming out of the very end of it. I have a good picture of it, but I cant figure out how to post it.
Old 11-05-2005, 10:55 AM
Rs051802 Rs051802 is offline
There is a seal where the yoke enter the transmission. If it is leaking onto the drivline, then that is probably your problem. The seal is fairly cheap if I remember right. All you need is a pair of needle nose and a flathead. Easy fix.
