Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 11-04-2005, 08:01 AM
artistek artistek is offline
Tire Pressure
What Tire pressure do you folks use in your tires?
Reason I ask:
I just had a Firestone tire rip at the seam at 75mph. The tires had 12,000 miles on them and Firestone claims they are not under warranty cause they are under-inflated. All 4 tires were at 31psi, and Firestone says they should be at 34 or 35. This caused me to go on a 3 day crusade to find the proper tire pressure for the LS. No kidding I called and talked to 14 people and have received 14 different answers. They range from 28psi to 37psi. Bridgestone-Firestone corporate offices says go with the sticker on the door (as does NHTSA, and almost every other web site). When I mentioned that the local Firestone dealer told me 34psi, Corporate backed up and said “the local dealer would know best”. Lincoln says " 30psi", Goodyear says " adjust to your comfort level, but never lower than the manufacturer recommendation" My dealer says “32psi is the right pressure”
So as you can see I’m still curious, any thoughts?
Old 11-04-2005, 09:01 AM
finance01 finance01 is offline
I think I put 35lbs of pressure in my 2000 LS. Another key thing is when I bought the car the tires on it where to light for the vehicle so it always looked underflated - then I bought a new set of tires and it works - runs - handles great. I took the car in for a rotation on the 17th of last month and he said I was letting my pressure get too low so he put 35lbs back in.
Old 11-04-2005, 09:32 AM
CGGorman's Avatar
CGGorman CGGorman is offline
Re: Tire Pressure
I would agree with the "adjust to your comfort level, but never lower than the manufacturer recommendation".
I run mine at 42 cold. The Vette is set to 28 (bigger tires, lighter car). My wife's car is 36/32 (f/r). My truck is 32.
ALL of them are inflated at or over the mfg. recommended pressure. It helps turn-in and mileage. Besides, I prefer a stiffer ride.
Also, I spoke with a Michelin tire engineer once and he said it's better to run your tires 5 pounds over than 2 pounds under.
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
