Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-03-2005, 11:10 PM
wrichards2005 wrichards2005 is offline
Transmission mount
I have a 91 accord automatic, and it shifts HARD when I'm slowing down (you can hear it click into gear), I am wondering if it is the mount, or possibly the cables. I don't know how to tell if the mount is bad, but I've heard if the CV joints are bad, that can cause it to "clunk," (my joints are bad), but I'm not sure its the problem.
Old 11-03-2005, 11:56 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Transmission mount
does it click when you go around corners, because bad CV's will do that. It could be the mounts or i think it could be something w/ vaccuum......i know that if the vaccuum is bad, it shifts hard when accelerating, but you'll have to wait for some more info from someone else......
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-04-2005, 10:23 AM
I know about the clicking around corners, but it clicks when I slow down to like 10 mph. Also, if I'm slowing down (not stopping) to like 15 mph and start accelerating again it shifts VERY hard.
Old 11-04-2005, 10:39 AM
Schister66's Avatar
AF -Advisor
i guess vaccuum is about the only thing i can think of....
Old 11-04-2005, 10:45 AM
But wouldn't vaccuum give me a code? I'm not getting an S-light code (typically for the transmission). If it is vaccuum, what kind of stuff can you think of. Before I got the car, someone put a crappy ass cold air filter on it. It sounds like a friggin whistle when its idling at a light. Do you think that has anything to do with it?
Old 11-04-2005, 10:53 AM
Schister66's Avatar
AF -Advisor
does it idle roughly?? Vaccuum could be something as simple as a really dirty or wet air filter. Vaccuum problems won't give you a code necessarily. When the vaccuum is all messed up, the car will shift like it would at wide open throttle.......
Old 11-04-2005, 11:39 AM
I changed the idle last week because it was too low, the air filter is good, its only like 2000 miles old.
Old 11-04-2005, 05:51 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
swap out the axle and check the motor mounts for tears. then proceed.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
