Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 11-03-2005, 09:14 PM
Cobra04 Cobra04 is offline
97 Neon will not start
Daughters neon will not start, garage said it's ahhh Fuel assembly or something, cost $400.
Problem is I forgot the part name. Does anyone know what this part might be called ?
They say its a neasy fix but part which is larger is expensive
Old 11-03-2005, 10:16 PM
TEXSRT4 TEXSRT4 is offline
Re: 97 Neon will not start
a pump/pickup assembly. it shouldnt be too bad. you can get it at autozone/pepboys/etc for cheaper than the dealer. install is cake. just drop the tank (2 straps, and a couple of fittings) and it comes right out. install is the exact opposite
Old 11-04-2005, 07:19 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
I think the fuel pump is in the fuel tank as mentioned, so it may be a bit messy.
Old 11-06-2005, 11:13 AM
palindromelol palindromelol is offline
89.00 bucks at autozone.
It is easy.. and can be messy.. If you have less than 1/8 of a tank of fuel, jacking up the passenger side 8" will flow all the gas to the drivers side of the tank. More gas than that? then you will have to drain it... there is a drain fitting on the pump/sending unit ahead of the passenger rear tire. It is right on the tank on a 4" diameter plastic plate.
To remove the pump/guage unit, which is in the tank, you need to remove a metal bracket next to the rocker panel.
You do not have to drop the tank. the pump will pop right out. You need a hammer and a brass or plastic drift pin to rotate the retaining clip off the above mentioned 4" plastic plate.
Asside from the gas spillage... and persnickity tube fitting retainers... it ought to be fairly easy..... 1-2 hours for a first timer. Hammer, drift pin.. a nut driver...that is about it.
