Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Old 11-03-2005, 06:55 PM
intothis1 intothis1 is offline
In need of opinions...
I just acquired an 85 CJ7 that's been sitting in the woods for 3 years.
Other than replacing fluids and battery, checking hoses and belt, anything you would do to get it ready to start?
Old 11-03-2005, 08:19 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: In need of opinions...
Pull out all the plugs and pour a spoonfull or 2 of ATF down each spark plug hole.
Put a big socket wrench on the crankshaft pully and rotate the engine over slowly by hand a few times. When you are sure it rotates smoothly, spin it with the starter to blow out the excess oil then put the plugs back in.
If its a standard trans, the clutch may be stuck (engaged) even when you press on the pedal, so be careful when starting it.
Spray the carb with carb cleaner and WD40 to make sure all the parts are moving freely. Be sure to replace any rubber fuel line between the fuel pump and the carb.
Try to pre-fill the carb float bowl with an ounce of gas through the bowl vent, if you can. It makes starting easier.
Old 11-04-2005, 05:39 AM
Ah, thanks MagicRat! I forgot about the plug holes.
Old 11-09-2005, 09:51 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Have you gotten it running??
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 11-09-2005, 04:43 PM
No I didn't. Got everything done that was recommended. It's trying, but as of yet, it hasn't turned over. One more thing to check tomorrow, and I'll try it again. I'll be back for more help no doubt..=)
Old 11-10-2005, 06:54 AM
If the battery is good, I'd suspect the starter.
Old 11-14-2005, 07:26 AM
We managed to get it running! Runs crappy, I think a good carb cleaning is in order. I did replace the cylinoid (sp) and now it shuts off when you take the key out..lol It does have a stuck valve, I'll get to that tomorrow. It goes into gear, and the brakes work, so it's not hopeless. I'm no longer looking at parting it out.
Old 11-14-2005, 07:30 AM
Sounds good!
Old 12-16-2005, 11:03 PM
oljeeptek oljeeptek is offline
Good job!
Remember...
Old Jeeps never die, they just sometimes look that way!
