Turbos
I have searched through this forum and have not found any threads on this.
Has anyone here had a custom turbo or supercharger built for there LS? And last question> Has anyone found a big brake kit besides Brembo for a 2000 LS? Thanks....... |
Re: Turbos
Stoptech makes (made?) a kit for the LS. It's about $4k for the brake kit, plus you'll need 18" wheels and tires.
Seems like I heard a story about a guy running remote turbo in the rear bumper of an LS. Can't confirm that, though. Quik LS is prototyping a blower as we speak.
Chris Gorman -LLSOC Forum Moderator- 2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..) |
@quick ls
I would like to hear of your progress on a blower system! I am in the process of having a custom turbo designed, I wanted to see if anyone has already had this done. |
Well - I'm getting close....
Have odds and ends to finish up and then tune. - air tube - vacuum lines - lower rad hose - boost gauge - belt
Quik LS - Austin, TX more, more, more..... #0018 ESP SCCA solo2 LLSOC.com - President see my mean LS see my Lotus Esprit - Quiker |
Re: Turbos
on the turbo - you're gonna have the same issues that many of the turbo kits are starting to have with these modern sedans - no room under the hood.
since the car is already running 10.55:1 compression you are not going to use must boost - and getting to the exhaust manifold it tough. A guy did do a whole turbo setup and tucked it under the rear bumper - but had issues and removed it all. I wish you luck - the more folks trying these things - the more market it will create. Tuning is the key - how are you planning to tune?
Re: Turbos
Ken Garrison 2001 Lincoln LSE Pics of my 2001 Lincoln LSE! ![]() LS Koncepts Luxury Sedan Aftermarket Parts |
Re: Re: Turbos
thanks for all the answers!
@quick LS I am finding that room is diffenitly an issue here. The bigger issue is software! We have thought about running a single T with low boost to create around 50hp to keep this system from fighting us. I have seen other rear turbo setups that ended up being something to laugh about at the bar later. We all would love the 3 second lag and spooling out on your opponets car when you already gone and he wishes he was in your car (or he is not a sleeper nos puffin 500hp Soy Burner). I would enjoy looking into your blower setup more. Is it procharger based? Any hood clearance issues? I am stumped that there is not more of a following for this car with aftermarket performance. Last has anyone considered engine swap on these? Last edited by xcadia; 11-08-2005 at 09:50 PM. |
Re: Re: Re: Turbos
@lead foot
Yes we have researched piggy backing this setup. But with these systems they will fight almost everything we do. If you come across any info.. please send it here.. Even with street tuners we look for 90 models to keep from dealing with this. I am hoping that others have passed these passages before on a LS and can send me the map! |
sorry changed work done.. when finished will repost
Re: Re: Re: Turbos
It's actually lower than the stock intake - so no hood clearance issues at all. on the aftermarket - the engine was only used in the T-Bird and LS - not enough owners of $40k+ cars are looking to modify to make parts viable. the engine swap is a major issue. modifying the PCM to manage a new engine would be next to impossible, while trying to match a standalone engine management system into the databus of the LS would be very difficult. Can you put another engine in it - sure (the OLOA LS had a Roush 4.6 SC) but to make your gauges work, ...etc is the challenge. As more new Fords come out using the newer PCM - the more likely this becomes.
Thank you again...
notes taken
If your running the 3.0L duratec engine, then www.arizonadynochip.com could probably build you a kit since they already build turbo kits for the ford contour/mercury cougar 2.5L and 3.0L duratec motors. Im running the T3/T4 kit on my Contour and love it.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
Re: Turbos
Quick ls. im intrested in supercharging my 2002 ls-8 as well. ive just recevied a bounus from the army and i have tons of spare time and car experiance. was wondering if you could share some tips. thanks
Re: Turbos
nope - the issue is that the LS PCM was the first Ford with the next gen PCM - now the F150, Mustang, ...etc use it as well. The key is tuning, and tuning the new PCM can only be done using SCT's Advantage software. If the shop is an SCT dealer and familiar with the LS - you 'should' be able to do anything.
